Integrate1D with MultiThread
hugh50935
I have a function which performs multiple Integrate1D's (one for each point in a large 4D matrix). Needless to say it's very slow, taking up to 48+ hours depending on the size of the matrix. This seems like a pretty good opportunity to use MultiThread, but apparently Integrate1D isn't ThreadSafe.
Does anyone know of a workaround for this?
Any help would be appreciated.
Cheers,
Hugh
May 3, 2011 at 01:16 am - Permalink
The matrix varies in size, depending on how much time I can afford to let it run for. Generally from 21^4 to 151^4 (the bigger the better).
Anyway, here's the function I integrate to:
The variables Gh1, Gh2 & Gm are constant across the matrix, wheras Gu0-Gu3 vary (they're linear with the row,column,layer,chunk index values). That is to say, my matrix plots LatScat vs Gu0 & Gu1 & Gu2 & Gu3.
Cheers,
Hugh
May 3, 2011 at 02:00 am - Permalink
Or, can you evaluate the function between the two limits, then use integrate (which is threadsafe)?
May 3, 2011 at 05:36 am - Permalink
Mathematica has a hard time with that particular integral (you get the form exp[ix sin[x]]). Generally this is solved by approximating with a limited number of terms of an infinite series of Bessell functions, but Mathematica gives me a very long solution after about 5mins for a single term. And that's still a solution approximated by Bessel terms. Numerical is definately the way to go here (plus all my other work on this particular problem is on Igor anyway).
Actually, I originally tried using integrate, but found the output wave was of the same dimension as the input wave (i.e. it should be a single number, right?). Clearly I was doing something wrong.
I think having another go with integrate may be the solution here, as it means I can do away with all the global values since I can just use them when I evaluate the function to begin with, right?
Are there any differences in the quality of the integration methods used in integrate vs integrate1D that you know of?
Thanks for your help!
Cheers,
Hugh
May 3, 2011 at 06:27 am - Permalink
If I remember correctly, the output from Integrate is not a single value but rather a wave, where the value of each point is the cumulative integral up to that point. So to get the total integral you need to take the last point of the output.
Integrate and Integrate1D differ in that the first integrates only tabulated values - Integrate does not know of any user-defined function. Integrate1D, on the other hand, does. So you could try to do each integration by tabulating all the values first, and then calling Integrate. This should very easy to parallellize using a wave assignment and the MultiThread keyword. Just be careful with the global variables, and consider replacing them with function arguments instead.
Unfortunately, this also means that you will have to decide at which values to tabulate the function. Integrate1D takes care of this for you, meaning that it can potentially make fewer function calls and/or obtain a higher accuracy. Integrate1D would also be conceptually much cleaner. I hope WaveMetrics chimes in on why it's not threadsafe, and whether they can address this to help you out.
Another way to obtain a speedup is to try to rewrite the integrated function in an XOP, which might make it much faster. But again the problem here is to get the extra information in there (i.e. the global variables). This can be hacked around, but it will not be pretty.
May 3, 2011 at 06:50 am - Permalink
AG, the author of Integrate1D is on vacation right now. I'm sure he will respond when he gets back next week.
May 3, 2011 at 09:25 am - Permalink
Especially options and count look like they influence the required time.
Your user defined function is also still pretty complicated. Have you checked that it runs fast enough?
For example you could precompute some of the terms, e.g.
and you can also precompute Gh1+Gh2 therefore skipping one multiplication. But maybe this might not be the real issue here.
Or maybe there is one fitting addition theorem which lets you calculate cos(a*PI*t) less than three times.
May 3, 2011 at 02:20 pm - Permalink
Thanks for all your suggestions.
I rewrote my function using Integrate, and tried to cut out superfluous multiplications. I made a 1D wave, integrated it and took the last value. 100 points in the wave seems to get pretty close to Integrate1D, which is nice.
Doing this means I could make my variables local again, and reduce the total number of functions, leaving me with this:
So, I just ran this on my desktop with a 20^4 data set, which wasn't a whole lot faster than the Integrate1D method (about 10-20% I guess). But on my less cluttered sever (4-core Xeon 5570) multithreading reduced the solving time by a factor of 4. The giveaway was that the CPU load went from 13% to 100% with multithreading. Good work, guys!
I'm not entirely happy with my integration (i.e. the bit in the FOR loop). Is there a way to streamline this using wave assignments? I feel like I want to replace 't' with 'p', but I don't know how since the Variable U is a function of 't' as well.
Cheers,
Hugh
May 3, 2011 at 06:43 pm - Permalink
Right. You won't be able to replace it with a wave assignment unless you directly substitute the expression for 'U' itself, which is certainly fine but will lead to a more cluttered expression.
So instead of this
you write
Then just replace 't' with 'p' and you'll be all set. Sure, it's a mess, but the compiler doesn't care.
Strictly speaking using 'p' means that you would sample your function at unit intervals, but you're addressing that by having
t/n
as the effective variable. I'd recommend you to use wave scaling to achieve this. Simply executeafter making the wave, and then replace any occurrence of
p/n
in the wave assignment withx
. That will clean it up some more. But in any case, make sure that you're sampling your function at a sufficiently high density to have a reliable result.May 3, 2011 at 07:02 pm - Permalink
Given my new increase in calculation speed from threading, increasing the sampling density of the integration shouldn't be an issue.
Now if I can get igor to email me when the calculation is finished on the server, life will be perfect.
Cheers,
Hugh
May 3, 2011 at 08:06 pm - Permalink
Well, you can get the Sockit XOP available from IgorExchange, and go to http://www.igorexchange.com/node/626.
But I think it wouldn't hurt if WaveMetrics made sending email a built-in operation. The reason I know of this snippet is because I'm also having Igor send me an email when a particular data-acquisition (that takes a few hours) is done.
May 3, 2011 at 09:01 pm - Permalink
May 3, 2011 at 10:33 pm - Permalink
A.
May 3, 2011 at 10:35 pm - Permalink
I looked at SOCKIT but chickened out and wrote a script in C# which I execute at the end of the program.
I agree it would be great if Igor had some socket functions and, more importantly, a convenient email notification tool.
Cheers,
Hugh
May 3, 2011 at 11:19 pm - Permalink
It's not as bad as it seems. Here's the function that I use to send email:
May 4, 2011 at 06:31 am - Permalink
Cheers,
Hugh
May 6, 2011 at 04:26 am - Permalink
