    VoigtFit not available
Unfortunately, the compilation of a procedure which uses this function leads to the following error : "While executing FuncFit, the following error occured: No used or external function of that name exists"
Looking at the CurveFiiting menu reveals that there is indeed no function with that name.
So, I do not understand what happens. Why the MultiPeakFit does not work ? The XOP alias has been correctly put in the Igor Extensions folder.
Is there anybody who had this trouble ?
Thanks a lot.
Eric
I hope this should be useful for other.
Eric
April 13, 2011 at 11:52 am - Permalink
[quote]The XOP alias has been correctly put in the Igor Extensions folder.[/quote]
Possibly you have multiple copies of Igor on your machine and put the extension in the wrong Igor Extensions folder.
Also, you should create shortcuts and put the shortcuts in "Igor Extensions" rather than moving the XOP file itself. That way, if we update the XOP, you will automatically use the updated XOP.
April 13, 2011 at 12:40 pm - Permalink
Eric[/quote]
Hi kiri,
I am a newer to Igor, now I am try to use Igor to deal with some data, especially the Voigt function is necessary.
I would be extremely grateful if you would can share me the Voigt function code complied with Igor language ?
You can post here or email to me : urion0625@hotmail.com
May 18, 2011 at 06:54 am - Permalink
