Folder Menu
This replaces my original primitive implementation of this idea, making a Folder menu that now handles hierarchy, among other refinements.
Thanks to Jim Prouty for his example code that showed me a better way of doing this.
// David Dana, 2011-3-16
// Creates a Folder menu for selecting among data folders, as an alternative to the Data Browser.
// Supports hierarchical folder structures, but somewhat kludgily since we can't make dynamic menus
// truly hierarchical.  See FolderMenuItems() description for complete description of menu behavior.
// Menu also includes a command for creating new folders (but not deleting).
<!--break-->
// Run MakeTestFolders() to quickly create some sample folders for experimentation.
#pragma version=1.00
Menu "Folder", dynamic
    FolderMenuItems(), FolderItemHandler()
    "New Folder...", FolderPromptNewFolder()
End Menu
//  Constructs a menu listing the current data folder, its parent, siblings, and children if any.
//  The first menu item is always the parent of the current folder, or root: if root: is current.
//  Then are listed all folders with the same parent as the current folder.
//  If the current folder has folders below it, these are also listed, indented below the current folder.
//  If the current folder has siblings with their own children (the current folder's nieces and nephews ;-) ),
//  those children are not shown, but their parents are marked with a '>'.   The user can view those children
//  by selecting the parent.
//  The currently active data folder is marked with a check, and disabled (since there is no point to
//  selecting it again).
//  David Dana, HOBI Labs, Inc. 2011-3-16
Function/S FolderMenuItems()
    string itemStr
    string currentDF = GetDataFolder(1) // Get complete folder path
    string parent = CurrentFolderParent(1)
    //  First menu item is the full path of the parent folder
    if (strlen(parent) == 0)    //  the current folder is root, there is no parent
        itemStr = DisablePrefix() + CheckMarkPrefix() + "root:;"
        parent = "root:"
        itemStr = parent + ";"
//  Find all children of parent (possibly including the current folder)
    variable i, itemCount = CountObjects(parent, 4)
    if (itemCount)
        itemStr = itemStr + "-;"
    //  Add each child to menu item list
        string child
        for (i = 0; i < itemCount; i += 1)
            child = getIndexedObjName(parent, 4, i)
            string childFullPath = parent + possiblyQuoteName(child) + ":"
            variable grandchildCount = CountObjects(childFullPath,4)
    // if this is the current folder, prefix checkmark and see if it has children
            if (stringmatch(currentDF, childFullPath))
                itemStr = itemStr + DisablePrefix() + CheckMarkPrefix() + child + ";"
                if (grandChildCount)
                    variable j
                    for (j = 0; j < grandChildCount; j+=1)
                        string grandChild = getIndexedObjName(childFullPath,4,j)
                        itemStr =  itemStr + "  " + grandChild + ";"  // prefix subfolders with 2 spaces for clarity
                    itemStr = itemStr + ParentPrefix() + child + ";"
                    itemStr = itemStr + child + ";"
    return itemStr
End Function  //--------------------------------------------------------------
//  Responds to a selection from the menu constructed by FolderMenuItems().
//  Extracts the path of a folder and sets that as the current data folder.
Function FolderItemHandler()
    GetLastUserMenuInfo
    String folderPath = S_Value
    Variable itemNumber = v_value
    variable isChild = StringMatch(folderPath, ChildPrefix() + "*")
    folderPath = StripPrefix(folderPath)
    string parentPath = StringFromList (0, FolderMenuItems(), ";")
    parentPath = StripPrefix(parentPath)
    if (itemNumber == 1)            // first item is the parent folder
        folderPath = "::"           // Go up one level
        if (!isChild)   // if child, folderPath is already correct
            folderPath = parentPath + possiblyquotename(folderPath)
    print folderPath
    SetDataFolder folderPath
// Append this to the front of a menu item to indicate the folder is child of a folder above it
Function/S ChildPrefix()
    Return "  "
// Append this to the front of a menu item to indicate the folder has children
Function/S ParentPrefix()
    Return "!>"
// Append this to the front of a menu item to disable it.  Can be added in front of other marks.
Function/S DisablePrefix()
    Return "("
// Append this to the front of a menu item to give it a check mark
Function/S CheckMarkPrefix()
    return "!" + num2Char(18)
// Removes special characters such as check marks, etc. from the front of a menu item name
Function/S StripPrefix(s)
string s
    if (stringmatch(s, "(*"))       // an open parenthesis makes the item inactive
        s = s[1,inf]
    if (stringmatch(s, "!!*") == 0)     // the initial ! is a logic inversion operator.
        s = s[2,inf]
    if (stringmatch(s, ChildPrefix() + "*"))
        s = s[strlen(ChildPrefix()), inf]
    return s
// Asks for the user for the name of a new folder.  Returns 0 if user cancelled or error.
Function FolderPromptNewFolder()
    string name
    prompt name, "Name for new folder in " + GetDataFolder (0)
    string promptStr = "New Data Folder"
    DoPrompt/HELP="" promptStr, name
    if (v_flag == 1)    // user cancelled
    if (CheckName(name, 11))
        DoAlert 0, "\"" + name + "\" is not a legal folder name or is already in use."
    NewDataFolder $name
    return 1
// Returns the name of the parent of the current folder, or empty string if the current folder is root:.
// If fullSpec is zero, returns only the base name of the parent, otherwise returns its full path
Function/S CurrentFolderParent(fullSpec)
variable fullSpec
    string folder = GetDataFolder(1)
    if (stringmatch(folder, "root:"))
        return ""
        variable items = ItemsInList (folder, ":")
        if (fullSpec)
            folder = RemoveListItem (items - 1, folder, ":")
            return folder
            return StringFromList (items-2, folder, ":")
// Just for testing
Function MakeTestFolders()
    NewDataFolder/O root:Folder1
    NewDataFolder/O root:Folder2
    NewDataFolder/O root:Folder3
    NewDataFolder/O root:Folder4
    NewDataFolder/O root:Folder5
    NewDataFolder/O root:Folder6
    NewDataFolder/O root:Folder7
    NewDataFolder/O root:Folder3:Child1
    NewDataFolder/O root:Folder3:Child2
    NewDataFolder/O root:Folder3:Child3
    NewDataFolder/O root:Folder3:Child4
    NewDataFolder/O root:Folder3:Child5
    NewDataFolder/O root:Folder3:Child6
I offer this Igor 6 or later alternative which allows you to move up and down the data folder hierarchy:
    FolderMenuItems(), /Q, HandleFolderMenuItem()
    String topFolder= GetDataFolder(1)
    String itemList ="(!"+ num2char(18) + topFolder+";"
    if( CmpStr(topFolder,"root:") != 0 )
        itemList +="::;"
    Variable i,n= CountObjects(topFolder, 4)
    for(i=0; i<n; i+=1 )
        String fName = GetIndexedObjName(topFolder, 4, i)
        itemList += fName+";"
    return itemList
Function HandleFolderMenuItem()
    GetLastUserMenuInfo
    String folderPath=S_Value
    Print S_Value
    SetDataFolder S_Value
It isn't possible to use dynamic menu items to create (or not) entire submenus, based on whether the item is a folder, right? If it were, we could dispense with the data browser entirely. Greate code, guys!
I like menu definitions with /Q in them because they don't echo commands I'm never going to re-execute manually from the History window:
    FolderMenuItems(),/Q, FolderItemHandler()
    "New Folder...",/Q, FolderPromptNewFolder()
End Menu
This is great. But....
Does anyone know what to do if there are a large (30 or more) number of subFolders? I get a "too many items" error in the Folder menu when I try this.
That's where this breaks down on Windows (not a problem on Macintosh). 30 is the practical limit. Invoke the Data Browser for the 30th item ("More...").
I regularly have 50+ folders to work with and find the "data Browser" slow and cumbersome if you just want to change Datafolders. Below might not be the most elegant code but this does seems to work on windows (limits display to 25 datafolders but adds the ability to go forward and backward 25 datafolders)
Folder Menu for windows.ipf (1.13 KB)
You could divide the data folders in each level into the 26 categories of starting letters, and define submenus for A, B, C, etc.
This is pretty hardcore by now...
