Layout resolution
benjamin.bertsche
I do have a problem with my layout pages.
The resolution of the layout page within Igor is very low (72 dpi), although the used printer has 600 dpi.
If I print the layout the resolution is 600 dpi but if I view the layout page in Igor the resolution is 72 dpi. Therefor I can't see the Graph properly and I'm forced to use the print preview to see how the layout really looks.
So my question is:
- How can I change the resolution of a layout page.
Thanks for your time,
Benny
PS: I'm using Mac OS X (Version 10.6.6) and Igor PRO (Version 6.00)
You can use embedded graphs instead of graph objects. When you zoom a page layout, the embedded graph is displayed at higher resolution.
To learn about embedding, execute:
It takes a bit of reading and work to get used to embedding. If that does not work for you you will have to depend on the print preview.
March 22, 2011 at 04:04 pm - Permalink
