Wandering popup menu
jdorsey
#pragma rtGlobals=1 // Use modern global access method.
function CAPS_Proc()
PauseUpdate; Silent 1 // building window...
NewPanel /W=(10,60,362,700) /N=CASProc
SetDrawLayer UserBack
TabControl capsMainTab disable=0, proc=caps_tab_proc, pos={2,65}, size={346,500}, tabLabel(0)="Load", tabLabel(1)="Analyse CAS", title="MainTab", win=casProc
caps_tab_proc("tmp",0)
function caps_tab_proc(name,tab)
String name
Variable tab
String/G mieProbe = ""
GroupBox CAPS_Correct_RI_Box,disable=(tab!=0),pos={8,280},size={334,105}
TitleBox CAPS_RI_Caption,frame=0,fsize=16,pos={75,282},disable=(tab!=0),title="Refractive Index / Diameter"
SetVariable realRIset,value=realRI,pos={15,305},size={86,18},title="Real",limits={0,10,0},disable=(tab!=0)
SetVariable imagRIset,value=imagRI,pos={105,305},size={86,18},title="Imag",limits={0,10,0},disable=(tab!=0)
SetVariable mdminset,value=Dmin,pos={15,325},size={86,18},title="Dmin",limits={0,10,0},disable=(tab!=0)
SetVariable mdstepset,value=Dstep,pos={105,325},size={86,18},title="Dstep",limits={0,10,0},disable=(tab!=0)
SetVariable mdmaxset,value=Dmax,pos={200,325},size={86,18},title="Dmax",limits={0,10000,0},disable=(tab!=0)
PopupMenu mieProbeCtl,bodyWidth=59,value="-;APSD;CAS;PCASP",pos={240,302},proc=probeselectmie,title="Probe",disable=(tab!=0)
ControlInfo mieProbeCtl
Button CAPS_Run_Mie,disable=(tab!=0),pos={300,307},size={25,25},proc=RunMieCode,title="Go!"
if(tab==0)
SetDrawEnv linefgc=(65535,65535,65535)
DrawLine 12,350,338,350
SetDrawEnv linefgc=(52224,52224,52224)
SetVariable xdminset,value=xDmin,pos={15,360},size={86,18},title="Dmin",limits={0,10,0},disable=(tab!=0)
SetVariable xdstepset,value=xDstep,pos={100,360},size={86,18},title="Dstep",limits={0,10,0},disable=(tab!=0)
SetVariable xdmaxset,value=xDmax,pos={190,360},size={86,18},title="Dmax",limits={0,10000,0},disable=(tab!=0)
Checkbox /Z useDefDiam disable=(tab!=0),variable=useDefaultDiameters,noproc,title="Default?",pos={280,360}
String name
Variable tab
if(tab==0)
The best way to create these commands is to set up your panel the way you want it to look, then save the window recreation macro, and paste the saved PopupMenu command into your function.
March 14, 2011 at 08:55 am - Permalink
Edit: Just tried changing the offending line to the following:
PopupMenu mieProbeCtl,value="-;APSD;CAS;PCASP",pos={240,302},bodyWidth=59,proc=probeselectmie,title="Probe",disable=(tab!=0)
and still see the same behaviour. Having already manually positioned everything where I want it using "pos=". I'll try making the window recreation macro and report back...
Edit 2: Popup menus seem very sensitive to the order in which seemingly unrelated options are presented, but after a vast amount of mucking about, the following seems to work:
PopupMenu mieProbeCtl,pos={170,302},size={120,220},bodywidth=60,value="-;APSD;CAS;PCASP",proc=probeselectmie,title="Probe",disable=(tab!=0)
Thanks again for the hint Jim.
March 14, 2011 at 11:39 am - Permalink
You're welcome. Note that the order you came up with is almost identically the order used by the window recreation macro.
That's no coincidence.
March 14, 2011 at 01:16 pm - Permalink
