Built-in Constants
Igor
for example:
Common name: Euler-Mascheroni gamma
Suggested name: kGammaEuler
Value: 0.5772156649015328606065
Units: None
Reference: http://en.wikipedia.org/wiki/Euler%E2%80%93Mascheroni_constant
Please respond by posting to this thread so that everyone can see the list as it is being compiled.
Common Name: Magnetic Constant \mu_0
Suggested Name: kMu0
Value: (Pi * 4e-7) [exact]
Units: N / (A^2)
Reference: http://physics.nist.gov/cgi-bin/cuu/Value?mu0|search_for=universal_in!
Common Name: Electric Constant \epsilon_0
Suggested Name: kEpsilon0
Value: 8.854 187 817... x 10-12 [exact]
Units: F/m
Reference: http://physics.nist.gov/cgi-bin/cuu/Value?ep0#mid
Common Name: elementary charge e
Suggested Name: kqe
Value: 1.602 176 487 x 10-19
Units: C
Reference: http://physics.nist.gov/cgi-bin/cuu/Value?e|search_for=elecmag_in!
March 1, 2011 at 02:39 pm - Permalink
Possible Name: Mol
Value: 6.02214078 x 10^23
Units: molecules/Mole
Reference: http://en.wikipedia.org/wiki/Mole_(unit)
Mac #513
March 1, 2011 at 03:31 pm - Permalink
Suggested name: kmassneutron
Value:1.674 927 211e-27
Units: kg
Reference: http://physics.nist.gov/cgi-bin/cuu/Value?mn
Common name: mass of proton
Suggested name: kmassproton
Value:1.672 621 637e-26
Units: kg
Reference: http://physics.nist.gov/cgi-bin/cuu/Value?mp
Common name: Plancks Constant
Suggested name: kPlanck
Value:6.626 068 96e-34
Units: Js
Common name: Speed of light in vacuum
Suggested name: kLightSpeed
Value:299 792 45
Units: m/s
Reference: http://physics.nist.gov/cgi-bin/cuu/Value?c
Common name: Avogadro
Suggested name: kAvogadro
Value:6.022 141 79e23
Units:
Common Name: Plancks constant divided by mass of neutron
Suggested name: kPlanckOverMassNeutron
Value:6.626e-34/1.674927211e-27
Units: Js/kg
Common Name: classical electron radius
Suggested name: kElectronRadius
Value:2.817 940 2894 e-15
Units: m
Reference: http://physics.nist.gov/cgi-bin/cuu/Value?re|search_for=Classical+elect…
Also need Boltzmann, ideal gas constant, etc
For ease of importing check out:
http://physics.nist.gov/cuu/Constants/Table/allascii.txt
I vote for static constants in an includable procedure file, accessible by a module name. Or by a function e.g. PhysConstant(0|1|3|4, etc)
March 1, 2011 at 03:09 pm - Permalink
Professor of Chemistry
University of Wisconsin Oshkosh
http://www.uwosh.edu/facstaff/gutow
Rather than list the ones I use most commonly, I would also second including the list from the NIST standards site. I periodically import an update of this for my own use. Unfortunately this text listing does not include common symbols.
If you go to the following page and select "table (pdf)" and then click on the button for "Extensive listings" you will get a .pdf file with all the constants and their preferred symbols. I recommend these be translated as follows:
Xy would be translated to an Igor constant name as X_y. Infinity symbols could be two little o's next to each other as in R_oo.
The link is: http://physics.nist.gov/cuu/Constants/index.html
I recommend this as an optional package with some sort of easy table to select constant names from. Maybe have them appear in a popup in the "Compose Expression" dialog.
My two cents.
Jonathan
March 1, 2011 at 03:26 pm - Permalink
Harald Stark
March 1, 2011 at 04:53 pm - Permalink
Common Name: Vacuum Impedance
Suggested Name: kZ0
Value: 119.916982 * Pi [exact]
Value: 376.730 313 461 77 [numeric]
Units: Ohm
Reference: http://en.wikipedia.org/wiki/Impedance_of_free_space
March 2, 2011 at 03:27 am - Permalink
Mac's comment: "Better, Newer" value in the wikipedia link above - difference is 0.000 001 01e23
I like the includable procedures file idea as well
March 2, 2011 at 07:19 am - Permalink
The earlier comment about units is appropriate. I do not have a good solution, but for the mac users, There is a very nice unit converter dashboard widget that understands mass energy-mass equivalence and atomic units at http://www.cberthod.homepage.bluewin.ch/vuc/widget.html
It even knows that c = 9.7156e-21 parsec/ps!
Common name: Si lattice parameter
Suggested name: aSi_A
Value:5.43102064
Units: Angstrom
Reference: http://physics.nist.gov/cgi-bin/cuu/Value?asil
Common name: hc in keV Angstroms
Suggested name: hc_keVA
Value:12.39841856
Units: keV Angstrom
Reference: http://physics.nist.gov/cgi-bin/cuu/Value?hev, http://physics.nist.gov/cgi-bin/cuu/Value?c
Common name: hc in keV nm
Value:1.239841856
Units: keV nm
Common name: Thomson radius
Suggested name: re_m
Value:2.8179402894e-15
Units: m
Reference: http://physics.nist.gov/cgi-bin/cuu/Value?sigmae, sigmae = 8*PI/3 * re^2
Suggested name: re_A
Value:2.8179402894e-5
Units: Angstrom
March 2, 2011 at 10:13 am - Permalink
Nomenclature ... see below
Units: SI
Values: all atomic masses
Units: g/mol
Proper implementation of the constants is a by far a more important factor for me. I personally would like access to the constants through (user-immutable -- they cannot muck them up on their own) structures, as below.
Having a functional way for users to be able to translate ASCII (tab-delimited, XML ....) tables of constants into immutable "#include" structures (containing symbol, value, unit layouts) and check for existence of terms would be a big help ...
March 2, 2011 at 10:31 am - Permalink
