Error propagation
Some code for error propagation (use at own risk, not triple checked it).
//http://en.wikipedia.org/wiki/Propagation_of_uncertainty
Function EP_add(a, da, b, db, c, dc, [covar])
wave a, da, b, db, c, dc
variable covar
    // C = A + B
    duplicate/free a, tempa
    duplicate/free b, tempb
    duplicate/free da, tempda
    duplicate/free db, tempdb
    redimension/n=(dimsize(a, 0), dimsize(a, 1), dimsize(a, 2), dimsize(a, 3)) c, dc
    if(paramisdefault(covar))
        covar = 0
    multithread c = tempa + tempb
    multithread dc = sqrt(tempda ^ 2 + tempdb ^ 2 + 2 * covar)
Function EP_sub(a, da, b, db, c, dc, [covar])
variable covar
    //C = A - B
        covar = 0
    multithread c = tempa - tempb
    multithread dc = sqrt(tempda ^ 2 + tempdb ^ 2 - 2 * covar)
Function EP_mult(a, da, b, db, c, dc, [covar])
variable covar
    //C = A * B
        covar = 0
    multithread c = tempa * tempb
    multithread dc = abs(c) * sqrt((tempda / tempa)^2 + (tempdb / tempb) ^ 2 + 2 * tempda * tempdb / (tempa * tempb) * covar)
Function EP_mulK(a, da, c, dc, k)
wave a, da, c, dc
variable k
    //C = k * A
    multithread c = tempa * k
    multithread dc = abs(tempda * k)
Function EP_div(a, da, b, db, c, dc, [covar])
variable covar
//C =  A / B
        covar = 0
    multithread c = tempa / tempb
    multithread dc = abs(c) * sqrt((tempda / tempa) ^ 2 + (tempdb / tempb) ^ 2 - 2 * tempda * tempdb / (tempa * tempb) * covar)
Function EP_pow(a, da, c, dc, k, [n])
wave a, da, c, dc
variable k, n
//C = n * (A ^ k)
    if(paramisdefault(n))
        n = 1
    multithread c = n * (tempa ^ k)
    multithread dc = abs(c * k * tempda / tempa)
Function EP_powK(a, da, c, dc, k, [n])
wave a, da, c, dc
variable k, n
//C = k ^ (A * n)
        n = 1
    multithread c = k ^ (tempA * n)
    multithread dc = abs(c * n * tempda * ln(k))
Function EP_ln(a, da, c, dc, [k, n])
wave a, da, c, dc
variable k, n
//C = n * ln(k * A)
    if(paramisdefault(k))
        k = 1
        n = 1
    multithread c = n * ln(k * tempa)
    multithread dc = abs(n * tempda / tempa)
Function EP_log(a, da, c, dc, [k, n])
wave a, da, c, dc
variable k, n
//C = n * log(k * A)
        k = 1
        n = 1
    multithread c = n * log(k * tempa)
    multithread dc = abs(n * tempda / (tempa * ln(10)))
Function EP_exp(a, da, c, dc, [k, n])
wave a, da, c, dc
variable k, n
//C = n * exp(k * A)
        k = 1
        n = 1
    multithread c = n * exp(k * tempa)
    multithread dc = abs(k * tempda * c)
Function EP_sin(a, da, c, dc)
wave a, da, c, dc
//C = sin(A)
    multithread c = sin(A)
    multithread dc = abs(cos(A) * da)
Function EP_cos(a, da, c, dc)
wave a, da, c, dc
//C = cos(A)
    multithread c = cos(A)
    multithread dc = abs(-sin(A) * da)
Assuming you have sufficiently fast and/or parallel computation, I wonder if it isn't usually easier to just get Monte Carlo error measurements. In other words, draw N initial values from a distribution that matches your measurements (e.g. mean = 3 cm, std = 0.4 cm), and run your usual, error-ignorant analysis on each of the N initial values, and then compute final errors from the distribution of the N results. Then you can use all of your existing code and never think about error propagation while you are writing new code.
Isn't a principled drawback to the MC method that it only gives the "true" values (those found by proper linear propagation methods) when N = infinity?
This code was developed for reducing scattering data where the uncertainty in a detector pixel is treated as Poissonian, i.e. the square root of the count. Then one has to correct the data, dividing through by other detector images, integrating, subtracting, etc. There are a multitude of steps and at each point the uncertainty is propagated. However it takes about 4s to correct a single image. This would have to be repeated a bazillion of times (http://en.wikipedia.org/wiki/Indefinite_and_fictitious_numbers for MC errors), given that there are a huge number of steps during the reduction. This would be a long time . So I'm putting my faith in the Central Limit Theorem.
