Getting information from image graphs
tfitzie
I am fairly new to using Igor Pro and am having a bit of a problem. I know that there is a way to get the raw data, or at least a rough estimate of the data, from an image of a graph. I think the function is called something along the lines of Igor Thief. IF someone could please help me out with this it would be much appreciated. I am trying to compare some of my data to that in a published paper and I need to do a bit of converting along the x-axis of the published work.
Thanks
#include <igorthief>
to the procedure window.After compiling you'll find the corresponding entry in the Packages submenu inside the Data menu.
A
February 3, 2011 at 04:51 am - Permalink
