Class Method using STRUCT and FUNCREF ?
I'd like to gather structures and their built-in functions (methods), like it's done in C++.
Indeed, I think it would be easier to maintain the code if we had the possibility to do so.
For example, to initialize the fields of a structure, one would do : Instance.init(45,55).
Below, I've tried to do it
#pragma rtGlobals=1 // Use modern global access method. main() function main() STRUCT test_struct PT PT.Initialisation(PT,50,55) //<<------------- Here print PT end /////////////////////////////////////////// Structure test_struct variable a variable b FUNCREF Init_a_b Initialisation EndStructure /////////////////////////////////////////// Function Init_a_b(instance_locale,C,D) STRUCT test_struct &instance_locale variable C,D instance_locale.a = C instance_locale.b = D End
As you can notice, this is not exactly what I'd like to do, as we are obliged to mention the object (structure) on which we act.
If I remember well, in C++ we have to use the THIS statement, which is not implemented in IGOR PRO.
So, my question is, Is there a workaround to write Object Oriented Code ?
Thank you in advance.
I must admit no experience in C or variants to help. However, as a general note, I am confused by why you are using the initialization call where parameter values are input. I consider initialization to be more "static", and generally would go about this as follows:
January 7, 2011 at 08:54 am - Permalink
Thank you for your answer. I didn't know this way to do. Because I'm trying to write a reusable code, It will certainly be helpful.
Best Regards
January 7, 2011 at 01:41 pm - Permalink
Some other C++ features that you will not be able to emulate in Igor are constructors, destructors, function overloading and inheritance. This all adds up to the conclusion that trying to emulate C++ in Igor will not buy you much, if anything. It will add complexity without adding any expressiveness.
You can write reusable code in any language by making routines general and organizing them into modules. What C++ and other object-oriented languages add to that is inheritance. You can't emulate inheritance in Igor.
Perhaps someday Igor will have support for object-oriented programming but not now.
You can write an Igor XOP in C++ using the Igor XOP Toolkit.
January 7, 2011 at 03:54 pm - Permalink
Thanks for all these explanations.
Best regards
January 10, 2011 at 05:09 am - Permalink
