Loading an entire directory
astrotool
Function CCNLoader() // Loads one file at a time, edits time wave, adds them to the proper waves, then deletes them do LoadWave/J/D/A=wave/K=0/L={4,6,0,0,0} if (V_flag == 0) // Break if user hit the cancel button. break endif GetFileFolderInfo/Z S_path+S_fileName if( V_Flag == 0 && V_isFile ) // file exists wave wave0 // changes time data -> Time and Date data wave0=X wave0+=V_modificationDate endif Concatenate/NP {wave0}, TimeAll Concatenate/NP {wave1}, CurrentSSAll KillWaves wave0,wave1 if (wAVEExists (wave48)) //check command history to see if there were alarms Killwaves wave48 print "ALARM!!!" else print "No Alarms" endif while(1) End
Files are recorded like this every hour
CCN data YYMMDDhhmmss.csv
CCN data 080601125425.csv
CCN data 080601135426.csv
CCN data 080601145427.csv
I don't understand your question. But I think the answer to your question is no. As far as I know, there's not really a way in any programming environment to load an entire directory at once, because directories are a collection of files and therefore each file must be loaded individually.
Maybe I'm not understanding your question.
June 10, 2008 at 05:55 am - Permalink
Consider that you have two functions ...
You can do one of the following:
June 10, 2008 at 11:43 am - Permalink
Yes. Execute this to see the relevant help:
DisplayHelpTopic "Loading All of the Files in a Folder"
June 10, 2008 at 12:44 pm - Permalink
