Lispix format
ChrLie
Is there any possibility to import raw-files in Lispix format into Igor:
https://www.nist.gov/services-resources/software/lispix
I would like to use Igor to handle "cube" data sets acquired from electron microscopy, which would be equivalent to 3D-waves, e.g. of the size "Make/B/U/N=(500, 500, 1024) cube". Those data are generated by spectral imaging, where each pixel of an image contains an energy dispersive spectrum.
Any ideas or suggestions how to import such data would be highly appreciated!
Cheers
Christian
GBLoadWave
is your friend.You could first extract the parameters from the .rpl file using, e.g., Open, FReadLine and sscanf, and then use that information as input for the GBLoadWave operation. The nomenclature ("little-endian" etc.) is exactly the same in GBLoadWave and the documentation links you posted.
Wolfgang Harneit
December 14, 2010 at 03:54 pm - Permalink
December 14, 2010 at 06:30 pm - Permalink
Hi Wolfgang,
thanks for pointing me towards GBLoadWave! I feel quite guilty now, seeing that you wrote this code apparently between 2 and 4 a.m.!
Thanks for your effort - using this I got some test data imported straight away, although it looks different to what I expected - I will look more carefully at the parameters!
Thanks again,
Cheers
Christian
December 15, 2010 at 08:07 am - Permalink
Wolfgang
December 15, 2010 at 09:57 am - Permalink
Cheers
Christian
December 15, 2010 at 10:55 am - Permalink
assumes that the data in the file is stored in "column major order" (see http://en.wikipedia.org/wiki/Row-major_order).
For a matrix, this means that, as you sequentially step through memory, all of the elements for column 0 appear consecutively, then all of the elements for column 1, and so on. Column major order is used by Igor and, according to the wikipedia article, by Fortran and Matlab.
C and many programs use row major order. For a matrix this means that, as you sequentially step through memory, all of the elements for row 0 appear consecutively, then all of the elements for row 1, and so on.
I'm a bit unclear on how this translates to 3D.
If your data is in row major order then you will need to shuffle it to put it in the right order. You would do this by duplicating it to create a temporary wave and then using wave assignment statements to pick the data out of the temporary wave and put it in the output wave in the right order.
December 15, 2010 at 01:52 pm - Permalink
it seems that this is likely the problem, because the imported 3D wave shows some regular patterns such that rows, columns or layers might have been mixed up.
I will start with a 1D wave and try to figure out the order.
Thanks
Christian
December 15, 2010 at 10:41 pm - Permalink
Redimension/N=(depth,width,height) $newname
for vector cubes. Then, you would have images in the YZ dimensions, and the X dimension represents the spectra. I guess you would want XY as image dimensions and Z as the spectral dimension. This could be achieved by leaving the Redimension line as it is and then picking out the data with
newWave[][][] = oldWave[(p + q*width)*depth + r]
or so. Of course, in any case you'd have to modify the surrounding code a bit (e.g. defer the
KillWaves oldWave
statement, declareWave NewWave= $newName
, etc.)Wolfgang
December 16, 2010 at 10:13 am - Permalink
Last week I completed a hack to load raw WiRE files (proprietary filetype used in Renishaw Raman spectrometers, may hold 1d or 2d arrays of spectra and spatial coordinates). Jamie Boyd's BinaryReader procedure was indispensable for figuring out the structure of the binary files. I've used it to hack several file types, including Bruker FTIR files. If you haven't already tried it, you should check it out!
Edit: Oops, I just realized that this is an old thread that was resurrected when links were fixed. Still, I recommend BinaryReader to anyone reading this!
July 27, 2018 at 08:01 am - Permalink
