AppendImage vs {wave0,wave1}
enhancedgemini
My current task is to distort an image with 20x20 pixels.
For the distortion I use an algebraic function.
What I do up to this day:
I transform every original pixel one-by-one to its new position and define its new rectangular borders.
Function DistortImage()
Make/O/N=(20,20) image //the original image as 2d-Wave
WAVE image = image
image= mod(x+y,2)//checker's board
Variable rows = DimSize(image,0)
Variable columns = DimSize(image,1)
Display/K=1
Variable i,j
for(j=0;j=rows-1;j+=1)
for(i=0;i=columns-1;i+=1)
String pixel = "color_" + num2str(i) + "_" + num2str(j)
String borderx = "borderx" + num2str(i) + "_" + num2str(j)
String bordery = "bordery" + num2str(i) + "_" + num2str(j)
Make/O/N=(1,1) $pixel //represents one pixel as a single image
Make/O/N=2 $borderx
Make/O/N=2 $bordery
WAVE color = $pixel
WAVE border_x = $borderx
WAVE border_y = $bordery
color = image[i][j]
border_x[0]=squared(i-0.5,j,0)
border_x[1]=squared(i+0.5,j,0)
border_y[0]=squared(i,j-0.5,1)
border_y[1]=squared(i,j+0.5,1)
AppendImage $pixel vs {$borderx, $bordery}
ModifyImage $pixel ctab= {0.8,1.1,Grays,0}
Function squared(x,y,bit) // some "random" function to scatter the pixels in a non-linear way
Variable x
Variable y
Variable bit
if (bit==0)
Variable x_out = (x+2)^2-(y+2)
return x_out
if (bit==1)
Variable y_out= (((y+2)^2)/(x+30))+x/2
return y_out
WAVE image = image
Display/K=1
Variable i,j
Make/O/N=2 $borderx
Make/O/N=2 $bordery
WAVE color = $pixel
color = image[i][j]
Variable x
Variable y
Variable bit
if (bit==0)
return x_out
if (bit==1)
return y_out
This approach is inefficient. The math behind the distortion only accounts to less than 1% of the computing time. For every single pixel, IGOR creates three waves. These waves are tiny, they only contain two elements. Yet, they fill up one "slot" in the Databrowser. For a 100x100 image, this sums up to 30,000 seperate waves. The effect is, that IGOR is progressively slowed down with every new additionally created wave.
The cause of all this trouble is this line:
AppendImage wave0 vs {wave1, wave2}
This command only works with seperate waves. It neither accepts subsets of bigger 1D-Waves, nor the columns of a matrix.
So, is there any workaround to this restriction?
If not, which other techniques may I look out for in order to distort an image ?
I hope this helps,
November 5, 2010 at 01:24 pm - Permalink
Thanks, Igor!
November 15, 2010 at 01:37 am - Permalink
