    area under the curve - FaverageXY
Dear Igor guru,
I am using FaverageXY to measure the area under the curve (AUC). According to Igor's manual (below), the AUC is calculated upon x=0. On the data that I have, it looks like the curve falling below x=0 would return a negative AUC. Is AUC the sum of the AUC measures above (positive) and below (negative) zero if the curve is across x=0 line?
Judy Chen
FaverageXY gives you trapezoidal average, not trapezoidal area. Use area and areaXY for area.
All of these are measured from y=0 in both positive and negative directions.
If you are still not certain what the functions do, try making some waves with a few points and explore what happens as you change the data.
November 15, 2024 at 09:34 am - Permalink
Yes, negative Y values contribute negative areas to the result:
If you want negative portions of your data to contribute nothing to the result, you can make a new data set with negative portions set to zero:
If you want negative portions to contribute positive areas to the result, the new data set would be formed using abs():
November 15, 2024 at 09:43 am - Permalink
Thank you for the suggestions!
Best,
Judy
November 15, 2024 at 10:04 am - Permalink
