trouble shoot: WaveRefIndexed
I am trying to obtain a list containing all the wave paths in a table using "WaveRefIndexed(windowNameStr, index, type)" as the following:
FFTWaveList = WaveRefINdexed ($tableName, "", 1)
A few questions:
1. "$" is not allowed: how do I refer to pre-defined "tableName", e.g, if tableName = "FFT_R1_trial1"?
2. What do I put for "index" if I want to collect all the columns in the table? I tried "", which failed to compile.
Judy
NOTE: I changed the name of the GetWaveListFromTable to GetWaveRefsFromTable to be more accurate.
The first parameter to WaveRefIndexed is documented as windowNameStr. The "Str" suffix indicates that the parameter is a string, not a name. $ converts a string to a name but we want a string here, not a name, so $ is not needed.
To get a list of all wave references for all waves in the table you will need a loop.
Here is a lightly-tested solution:
Function/WAVE GetWaveRefsFromTable(String tableName)        // Returns free wave reference wave
    Make/WAVE/N=0/FREE refs
    int index = 0
    do
        int wType = 1       // Data columns only
        WAVE/Z w = WaveRefIndexed(tableName, index, wType)
        if (!WaveExists(w))
            break
        Redimension/N=(index+1) refs
        refs[index] = w
        index += 1
    while(1)
    return refs     // Free wave reference wave
Function Demo()
    KillWindow/Z DemoTable
    Make/O demoWave0, demoWave1
    Edit/N=DemoTable demoWave0, demoWave1
    WAVE/WAVE refs = GetWaveRefsFromTable("DemoTable")  // Free wave
    int i
    int numWaves = numpnts(refs)
    for(i=0; i<numWaves; i+=1)
        WAVE w = refs[i]
        String name = NameOfWave(w)
        Printf "%d: %s\r", i, name
The GetWaveRefsFromTable function returns a free wave containing wave references. For details on free waves, execute:
DisplayHelpTopic "Free Waves"
For details on wave reference waves, execute:
DisplayHelpTopic "Wave Reference Waves"
Thank you for helping with the WaveRefIndexed function. After I obtain the wave references for all waves in the table, I need to average the waves using:
       fWaveAverage(waveReferences, "", 0,0,"AveWave","")
I am having trouble finding the "fWaveAverage" function in the manual book. Looks like the first part in the parenthesis should be "refs". What do the other elements in the parenthesis stand for?
Also, when I manually averaged waves within a table using "Analysis-Package-Average Waves," the function outputted 2 parameters: W-WaveAverage and W_WaveAveError. How do I accomplish the same with "fWaveAverage"?
Judy
NOTE: I changed the name of the GetWaveListFromTable (above) to GetWaveRefsFromTable to be more accurate.
fWaveAverage is a function added by the "Waves Average.ipf" WaveMetrics procedure file. To use it you need to add this to your procedure file:
#include <Waves Average>
The first parameter to fWaveAverage is a string list of wave names or paths to waves, not a wave reference wave.
Here is a function that illustrates using fWaveAverage. As noted in a comment, it works only if all of the waves are in the same data folder:
// This works only if all of the waves in the table are in the same data folder
Function Demo2(String tableName)
    Make/O demoWave0={1,2,3}, demoWave1={2,3,4}
    String optionsStr = "WIN:" + tableName
    String list = WaveList("*", ";", optionsStr)
    String outputErrorWaveName = "StdDevOfWavesInTable"
    String outputWaveName = "AverageOfWavesInTable"
    int errorType = 1       // Standard deviation
    int errorInterval = 1   // I don't know what this parameter means
    fWaveAverage(list, "", errorType, errorInterval, outputWaveName, outputErrorWaveName)
    AppendToTable $outputWaveName, $outputErrorWaveName
Here is a function that works with fWaveAverage even if the waves are not in the same data folder. It uses the GetWaveRefsFromTable function above:
// This works even if the waves in the table are in different data folders
Function Demo3(String tableName)
    NewDataFolder/O root:DF0
    Make/O root:DF0:demoWave0={1,2,3}
    NewDataFolder/O root:DF1
    Make/O root:DF1:demoWave1={2,3,4}
    Edit/N=DemoTable root:DF0:demoWave0, root:DF1:demoWave1
    WAVE/WAVE refs = GetWaveRefsFromTable(tableName)    // Free wave
    String list = ""
    int i
        WAVE w = refs[i]
        String path = GetWavesDataFolder(w, 2)  // Full path including wave name
        // Printf "%d: %s\r", i, path
        list += path + ";"
Thank you, hrodstein! I updated my script by including "fWaveAverage" (script attached). The program is able to return the average and standard deviation. However, there are a couple of glitches as below.
(1) When I ran the script, looks like "newdatafolder" did not pass, leading to the following error message. (The glitch in the script bolded.) The outputted strings, "newdatafolderName" and "path" look appropriate since I can use them in Command window to create the desired new datafolder and setdatafolder to the newly created folder.
(2) Also, "Analysis-Package-Average Waves" returns standard error whereas the "fWaveAverage" returns standard deviation. Is there another errorType that can return standard error?
menu "Macros"
       "average FFTs", createAverageFFTsDialog()
Function createAverageFFTsDialog()
        variable age_min, age_max, sexNum1, sexNum2
        string PCAstatus
        prompt age_min, "Enter minimum age"
        prompt age_max, "Enter maximum age"
        prompt sexNum1, "Enter sex1"
        prompt sexNum2, "Enter sex2"
        prompt PCAstatus, "Enter PCA status", popup, "Aging;noAging;all"     //aging is PCA<-1, noAging is PCA>=-1
        DoPrompt "Enter group specs", age_min, age_max, sexNum1, sexNum2, PCAstatus
        //create new data folder
        string newdatafolderName = "'avgFFTs_artRatio15Perc_"+num2str(age_min)+"-"+num2str(age_max)+"_"+num2str(sexNum1)+"-"+num2str(sexNum2)+"_"+PCAstatus+"'"
        string path = "root:" + newdatafolderName
        newdatafolder path
        setdatafolder path
        //create "numWavesAverage" to summarize the number of waves averaged in each table
        make/T/FREE outputNameList = {"PDmm", "R1", "R2", "B1", "B2", "postR", "postB"}
        make/WAVE/N=0/FREE FFTWaveList        //create a wave to hold the list of wave references from each table
        string list            //list is the string list of all waves in the table
        string pathName        //pathName is the full path including wave name for each waves in the table
        variable trialNumber, c, i
        Int index, numWaves
        string FFTavgName, FFTavgErrorName
        string tableName
        for (trialNumber=1; trialNumber<=2; trialNumber+=1)
               for (c=0; c<7; c+=1)
                       tableName = "FFT_"+outputNameList[c]+"_trial"+num2str(trialNumber)
                       //obtaining wave references of all waves in the table
                       index = 0
                       Do
                               WAVE/Z w = WaveRefIndexed(tableName, index, 1)
                               if(!WaveExists(w))
                                      break
                               redimension/N=(index+1) FFTWaveList
                               FFTWaveList[index] = w
                               index += 1
                       while(1)
                       //obtaining string list of all waves in the table
                       list = ""
                       numWaves = numpnts(FFTWaveList)
                       for (i=0; i<numWaves; i+=1)
                               WAVE w=FFTWAVEList[i]
                               pathName = getwavesdataFolder(w, 2)
                               list += pathName + ";"
                       //averaging waves in the table
                       FFTavgName = "W_WaveAverage_"+outputNameList[c]+"_T"+num2str(trialNumber)
                       FFTavgErrorName = "W_WaveAveError_"+outputNameList[c]+"_T"+num2str(trialNumber)
                       fWaveAverage(list, "", 1, 1, FFTavgName, FFTavgErrorName)
Many thanks,
Judy
To insert Igor code in a post, click "Insert Code Snippet". This will format the code properly. For details, see https://www.wavemetrics.com/forum/general/formatting-code-forum-posts
NewDataFolder and SetDataFolder take a path as a parameter, not a string, so you need to use $path instead of path as the parameter.
Change the third parameter of the fWaveAverage call from 1 to 3. I discovered this by right-clicking "fWaveAverage" and reading the comments for the parameters.
Haaa - I wondered how to make the pasted code look original. Thank you for the tips!
Where do you right-click? I tried within the Procedure window and at the bottom of the Data Browser window, and I had trouble seeing the comments.
Judy
You can right-click the word "fWaveAverage" in your procedure file and choose "Go to fWaveAverage". This opens the "Waves Average" procedure file and displays the code for fWaveAverage.
