error message on VISAWrite
deltasigma
VISAWrite InstrumentID, "command"
It returned an error message "expected a keyword or an object name".
Does anyone knows how to fix it? Thanks first.
Igor Pro Version: 6.1.2.1
LabVIEW 2009
Windows Vista 32-bit
Most likely you haven't installed the VISA XOP. Select Help->Show Igor Pro Folder to get an Explorer window showing the contents of your Igor Pro folder. Find More Extensions:Data Acquisition:VISA.xop. Right-click, select Copy. Back in Igor, select Help->Show Igor Pro User Files Folder. Open the Igor Extensions folder; right-click and Paste Shortcut. Re-start Igor.
September 14, 2010 at 03:09 pm - Permalink
Yes that trick worked. Thanks a bunch!
No complaint, but why can't Igor automatically search for these .xop files located in the \More Extensions folder? It's just not that convenient to do it manually.
September 14, 2010 at 04:01 pm - Permalink
September 14, 2010 at 06:18 pm - Permalink
