one way to plot 3D hydrogen atom orbitals
Yuan Fang
I wrote a code to plot 3D hydrogen atom orbitals. I first expressed the orbital wavefunction in spherical coordinates and then transformed to xyz coordinates in order to do isosurface Gizmo plot in Igor.
function create() variable n=5,l=3,m=0 variable size1=400,size2=400 wave w=calcparametric(N,L,M,size1,size2) execute "Gizmo0()" end function/wave calcparametric(N,L,M,size1,size2) variable N,L,M,size1,size2 make/d/o/n=((size1)^2*(size2)) wavex,wavey,wavez,ff variable i,j,k,dt,df,psi2,rr,theta,phi,t=0 variable xx,yy,zz dt=pi/size1 df=2*dt for(i=0;i<size1;i+=1) theta=i*dt for(j=0;j<size1;j+=1) phi=j*df for(k=0;k<size2;k+=1) rr=k*0.05 variable temp1=factorial(n+l),temp2=factorial(n-l-1),temp3=laguerrea(n-l-1,2*l+1,2*rr/n/0.529) psi2=magsqr(sqrt((2/n/0.529)^3/2/n/(temp1)^3*temp2)*exp(-rr/n/0.529)*(2*rr/n/0.529)^l*temp3*sphericalHarmonics(l,m,theta,phi)) ff[t]=psi2 wavex[t]=rr*sin(theta)*cos(phi) wavey[t]=rr*sin(theta)*sin(phi) wavez[t]=rr*cos(theta) t+=1 endfor endfor endfor concatenate/np=1 {wavex,wavey,wavez,ff},dest Variable pee, qew, kappa variable u,v,z make/n=((size2)/10,(size2)/10,(size2)/10)/d/o kcube=0 setscale/p x,-0.05*size2,1,kcube setscale/p y,-0.05*size2,1,kcube setscale/p z,-0.05*size2,1,kcube duplicate/o kcube, BlueJacobian BlueJacobian = 0 for (j=0; j<DimSize(dest,0); j+=1) pee = round((dest[j][0] - DimOffset(kCube,0))/DimDelta(kCube,0)) qew = round((dest[j][1] - DimOffset(kCube,1))/DimDelta(kCube,1)) kappa=round((dest[j][2] - DimOffset(kCube,2))/DimDelta(kCube,2)) if (pee >= 0 && pee < DimSize(kCube,0) && qew >= 0 && qew < DimSize(kCube,1)&& kappa >= 0 && kappa < DimSize(kCube,2)) kCube[pee][qew][kappa] += dest[j][3] BlueJacobian[pee][qew][kappa] += 1 endif endfor for(u=0;u<DimSize(kCube,0);u+=1) for(v=0;v<DimSize(kCube,1);v+=1) for(z=0;z<dimsize(kcube,2);z+=1) kCube[u][v][z] /= max(1,BlueJacobian[u][v][z]) endfor endfor endfor killwaves dest,BlueJacobian,wavex,wavey,wavez,ff return kcube end Window Gizmo0() : GizmoPlot PauseUpdate; Silent 1 // building window... // Building Gizmo 8 window... NewGizmo/W=(21,44,330,320) ModifyGizmo startRecMacro=700 ModifyGizmo scalingOption=63 AppendToGizmo isoSurface=root:kcube,name=isoSurface0 ModifyGizmo ModifyObject=isoSurface0,objectType=isoSurface,property={ surfaceColorType,1} ModifyGizmo ModifyObject=isoSurface0,objectType=isoSurface,property={ lineColorType,0} ModifyGizmo ModifyObject=isoSurface0,objectType=isoSurface,property={ lineWidthType,0} ModifyGizmo ModifyObject=isoSurface0,objectType=isoSurface,property={ fillMode,2} ModifyGizmo ModifyObject=isoSurface0,objectType=isoSurface,property={ lineWidth,1} ModifyGizmo ModifyObject=isoSurface0,objectType=isoSurface,property={ isoValue,1e-08} ModifyGizmo ModifyObject=isoSurface0,objectType=isoSurface,property={ frontColor,1,0,0,1} ModifyGizmo ModifyObject=isoSurface0,objectType=isoSurface,property={ backColor,0,0,1,1} ModifyGizmo setDisplayList=0, object=isoSurface0 ModifyGizmo autoscaling=1 ModifyGizmo currentGroupObject="" ModifyGizmo showInfo ModifyGizmo infoWindow={559,7,1392,321} ModifyGizmo endRecMacro ModifyGizmo SETQUATERNION={-0.681597,0.118549,-0.123937,0.711347} EndMacro
A few comments in no particular order:
1. I assume that you are familiar with the old example under File Menu->Example Experiments->Visualization->SphericalHarmonicsDemo.
2. Both the code above and the demo experiment could benefit from multithreading as it took a long time to compute.
3. Your isoValue choice of 1e-8 is curious. To determine a better value I recommend executing:
This should indicate that a more appropriate isoValue may be ~2e-15.
May 9, 2024 at 08:24 am - Permalink
In reply to A few comments in no… by Igor
Thank you.
May 9, 2024 at 06:57 pm - Permalink
