Return multiple arguments via return in functions
Hello all,
I am using function to fit a peak in a 1D wave and get the fit coefficients. It works very well, however, I wonder if I could return all the fit coefficients using the return statement.
function analyze_peak(input, xaxis, startP, endP)
    wave input
    wave xaxis
    variable startP
    variable endP
    // get initial guess
    variable baseline = ( input[0] + input[1] ) /2
    wavestats /Q input
    variable guess_ampl = abs(V_max - V_min)
    variable nRows = dimsize( input, 0)
    make /o /d /n=(5) init_guess    // gaussian fit coefs
    // --- assign initial guess ----
    init_guess [0] = baseline
    init_guess [1] = 1.7e-8
    init_guess [2] = guess_ampl
    init_guess [3] = 1748
    init_guess [4] = 14
    //print "initial : ", init_guess
    FuncFit /Q  gauss_slope init_guess input  /X=xaxis
    // test fit
    make /o /d /n=(nRows) residual = input  - ( gauss_slope( init_guess, xaxis ) )
    make /o /d /n=(nRows) resd_abs = abs(residual)
    // statistics on residual
    wavestats /Q residual
    variable maxVal = wavemax(resd_abs)
    //print maxVal, v_avg, v_sdev
    if ( ( maxVal  < 3.6e-4 ) && (v_sdev < 5e-5) )
        //print "optimized : ", init_guess
        return init_guess[2]    // amplitude    (passing this to other function)
        return 0    // amplitude
    killwaves /Z init_guess, residual, resd_abs
One way is to use a temporary 1D wave to keep the fit coefficients and use it to move the fit coeffcients to other functions  / programs. Is there better way to do that.
Thanks.
Using a 1D wave is probably the easiest, and certainly the most frequently used way.
You can return multiple parameters, execute DisplayHelpTopic "Multiple Return Syntax" for details.
Since waves are passed by reference, you can pass a wave to a function and reset the values within the function.
Or you can write a function that returns a wave. That way you would create the coefficient wave in the function and return the wave for use elsewhere. I find that method to be the most readable:
function/wave GetAWave()
   make/free foo = {1,2,3}
   return foo
tony's response is just about perfect. I will just add in my personal preference. I like to use multiple returns in order to use named variables in the function signature. I find that helps me remember what the return values represent.
-Kris
