Igor9 slow running Macro function
rhoover
I am looping through a function in Igor9 and the first several times I run the function (~100 times) the function runs at an okay speed (a few seconds), but the more I loop through the function the longer it takes. It goes from running in a few seconds to several minutes. I have run this function in Igor8 and have had no problem with the performance slowing down. Any idea why it would be slowing down in Igor9?
Are you able to share the code that you're running?
January 23, 2024 at 05:31 pm - Permalink
Hi Ben - I am happy to share the file/code I am using but the file is ~2GB. Is there another way I can send you the file other than attaching to this forum thread. Google files or dropbox would work for me.
January 23, 2024 at 06:22 pm - Permalink
@rhoover Could you email support@wavemetrics.com with your system information? That way we can start a ticket for this and get it figured it out
January 24, 2024 at 09:17 am - Permalink
In reply to @rhoover Could you email… by Ben Murphy-Baum
Yup, just did. thanks!
January 25, 2024 at 08:56 am - Permalink
