It really depends on the dimensionality in question. In IP6 there is a demo experiment for a 3D vector field. Go to File Menu->Example Experiments->Visualization->Advanced->Scatter Arrows. A 2D example is in File Menu->Example Experiments->Graphing Techniques->Arrow Plot.
Let me add my support to the (implicit) request here. I have looked at the "Arrow Plot" demo, and it is far too complicated to be useful in practice. What is needed is a plot type analogous to "Contour Plot"s, which would just need a matrix and then be able to make a quick plot, with a dialog to adjust appearance.
John Bechhoefer
What's the usual data format for the 2D vector plot?
A 2D complex matrix?
For "adjust appearance" is there much beyond a scale factor for the vector lengths?
John Bechhoefer
In the Igor context, it would either be a function, a REAL matrix, or possibly a set of XY pairs. Igor would then have to do some work to numerically estimate the local gradient and then come up with the arrow. This would be a task analogous to the work required to figure out contours in a contour plot. (Indeed, the arrows are, of course, just locally perpendicular to contours, so the same routines might be used in both.) On the same topic, a streamline option would also be useful. (This is a plot of lines that are generated by "connecting the arrows all together to form a curve" and are, again, perpendicular to contour plots. They correspond to integrating the 2d-ODE associated with the vector field.)
Not usually, but perhaps an option.
Well, there would be color and other graphics parameters (thickness, arrow-head shape, etc.) for the arrows themselves (+ option to have either just lines (no arrow heads) or "nails" (flat heads) are also useful. For streamlines, all the options in contour plots would be useful.
We finally had a need to do a vector-field plot. The built-in option that now exists is great! (Confession -- at first, it didn't work; then I actually read the help file carefully and realized that the length units are points, not the graph xy units, and also that 2d wave format is r-theta and not xy. After that, it was smooth sailing.)
HTH,
October 17, 2008 at 09:39 am - Permalink
John Bechhoefer
February 4, 2009 at 01:53 pm - Permalink
February 9, 2009 at 08:11 pm - Permalink
John Bechhoefer
February 13, 2009 at 05:45 pm - Permalink
Belated thanks to the Igor folks for adding this!
February 17, 2012 at 12:15 pm - Permalink
In reply to by bech
Hi John: What is the "built-in option" that you used?
January 14, 2024 at 03:33 pm - Permalink
I think the built-in option was "Wind Barbs":
DisplayHelpTopic "Wind Barb Plots"
January 14, 2024 at 07:05 pm - Permalink
