Quick Syntax Highlighting
RGerkin
Use this node to paste arbitrary code in between the igor tags, for the purposes of syntax highlighting Igor code, for use in copying and pasting into emails and anything else that will accept html. Ideally, do not actually submit changes to this code; just preview them with the "Preview" button, select the syntax-highlighted code, and move on.
// Arbitrary code is placed here.
September 1, 2010 at 08:03 am - Permalink
When you copy from a web page on Safari Macintosh and Internet Explorer on Windows, RTF is stored in the clipboard so the CSS is no longer needed. You can paste into any program that understands RTF on the clipboard (Igor does not).
September 1, 2010 at 05:29 pm - Permalink
September 2, 2010 at 08:42 am - Permalink
September 6, 2010 at 08:05 pm - Permalink
