Find Big Waves
In order to clear memory and reduce file sizes, it helps to be able to find the big waves, wherever they are.
// Returns the name of any waves exceeding 'minSize' points wherever they are found in any directory.
Function FindBigWaves(minSize[,df,depth,noShow])
    Variable minSize // A minimum number of points, e.g. 100000
    variable depth // Used by the function recursion.  Ignore.
    variable noShow // Don't show the table at the end.
    dfref df // A folder to use as the top level of the search.  Default is root:
    if(paramisdefault(df))
        dfref df=root:
    if(depth==0)
        NewDataFolder /O root:Packages
        NewDataFolder /O root:Packages:FindBigWaves
        dfref packageDF=root:Packages:FindBigWaves
        Make /o/T/n=0 packageDF:names
        Make /o/n=0 packageDF:sizes
    variable i
    wave /T/sdfr=packageDF names
    wave /sdfr=packageDF sizes
    variable points=numpnts(names)
    for(i=0;i<CountObjectsDFR(df,1);i+=1)
        wave w=df:$getindexedobjnamedfr(df,1,i)
        if(numpnts(w)>minSize)
            names[points]={GetWavesDataFolder(w,2)}
            sizes[points]={numpnts(w)}
            points+=1
    i=0
    Do
        string folder=GetIndexedObjNamedfr(df,4,i)
        if(strlen(folder))
            dfref subDF=df:$folder
            FindBigWaves(minSize,df=subDF,depth=depth+1)
            break
        i+=1
    While(1)
    if(depth==0)
        sort /R sizes,sizes,names
        if(!noShow)
            if(wintype("BigWaves"))
                dowindow /f BigWaves
                edit /K=1 /N=BigWaves names,sizes as "Big Waves"
Don't forget the imagetransform compress operation, which will prevent you having to lose those big waves.
I am interested in finding the size in bytes and needed to account for multidimensional as well as different wave types. So I took the code posted above (thank you) and some code posted by Howard for file type sizing and added in multidimensional sizes.
// Returns the name of any waves exceeding 'minSize' points wherever they are found in any directory.  Modified from RGerkin's code.
        dfref df=root:
    if(depth==0)
    variable i
            sizes[points]={sizeOfWave(w)}
            points+=1
    i=0
    Do
        if(strlen(folder))
            break
        i+=1
    While(1)
    if(depth==0)
        if(!noShow)
// posted by Howard in the forums
Function sizeOfType(inType)
    Variable inType
    Variable size=1
    if(inType & 0x01)
        size*=2
    if(inType & 0x02)
        size*=4
    elseif(inType & 0x04)
        size*=8
    elseif(inType & 0x10)
        size*=2
    elseif(inType & 0x20)
        size*=4
    elseif(inType==0)
        size=nan
    return size
//My addition to account for multidimensional waves
Function SizeOfWave(w)
    wave w
    variable index, wavesize
    wavesize =1
    For(index=0;index<wavedims(w);index +=1)
        wavesize *=DimSize(w,index)
    wavesize *=sizeOfType(wavetype(w))
    return wavesize
@hegedus:
Your snipped includes this function:
    wave w
    wavesize =1
    return wavesize
This can be rewritten as:
    wave w
    wavesize =numpnts(w) * sizeOfType(wavetype(w))
    return wavesize
Also, note that this will not really work for text waves, data folder reference waves, or wave reference waves. Each point of a text wave can take up a different number of bytes, depending on the length of the string that is stored in that point. You could call strlen() on each point of a text wave to get a pretty good estimate of the number of bytes the wave will take up. The SizeOfWave function also doesn't account for the size of the wave's header, but every wave header is the same size and is usually relatively small compared to the size of the wave's data.
Here is a version for IP7 which uses the SIZEINBYTES value from WaveInfo and works with wave reference waves as well.
I also changed the first parameter to mean size in MB instead of number of points.
/// Returns the name of any waves exceeding 'minSize' points wherever they are found in any directory.
/// Modified from RGerkin's and hegedus code.
Function FindBigWaves(minSizeInMB[,df,depth,noShow])
    Variable minSizeInMB // Minimum size in MB, e.g. 100
        dfref df=root:
    if(depth==0)
    variable i
        variable size = sizeOfWave(w)
        if(size > minSizeInMB)
            sizes[points]={size}
            points+=1
    i=0
    Do
        if(strlen(folder))
            FindBigWaves(minSizeInMB,df=subDF,depth=depth+1)
            break
        i+=1
    While(1)
    if(depth==0)
        if(!noShow)
Function SizeOfWave(wv)
    wave/Z wv
    variable i, numEntries
    variable total = NumberByKey("SIZEINBYTES", WaveInfo(wv, 0))
    if(WaveType(wv, 1) == 4)
        WAVE/WAVE temp = wv
        numEntries = numpnts(wv)
        for(i = 0; i < numEntries; i += 1)
            WAVE/Z elem = temp[i]
            if(!WaveExists(elem))
                continue
            total += SizeOfWave(elem)
    return total / 1024 / 1024
