polar graph:: New package
hello;
 after installed the newest version 9.03 of  igor pro.
 I tried to build a new polar graph or updata the older polar that I made before.
I recalled the polar graph panel.
some troubles I met::
1; if I want to draw new one through the "new polar setting from", I choose the pre-exist one, click "new polar graph". it reports "layer not available".
2; in the "append to polargraph" part;  the option operation failed.
Can you post an example experiment where that happens? Can you build a completely new polar graph without problems? If you think that this is a bug with the new version you could also write directly to the support.
Igor 9.04 (due out very soon) contains fixes for the 9.03 problem of "Use Polar Settings From" when creating new polar graphs from existing 9.02 or earlier graphs.
I have removed the temporary fixes in favor of having people update to 9.04.
