Hampel filter function
Yuan Fang
I wrote a function for Hampel filter. If anyone can help me check whether it is correct or nor? Thanks a lot.
function hampel(imgraw,k,nd) wave imgraw variable k,nd duplicate/o imgraw,imgraw_smth variable lx = dimsize(imgraw,1) make/o/n=(lx) iLo=p-k make/o/n=(lx) iHi=p+k variable i,j for(i=0;i<lx;i++) if(iLo[i]<0) iLo[i] = 0 endif endfor for(i=0;i<lx;i++) if(iHi[i]>(lx-1)) iHi[i] = lx-1 endif endfor for(i=0;i<dimsize(imgraw,0);i++) for(j = 0;j<lx;j++) duplicate/o/rmd=[i,i][iLo(j),iHi(j)] imgraw,temp matrixtranspose temp make/n=(dimsize(temp,0))/d/o w w=temp variable medj = median(w) make/d/o/n=(lx) mmed,mmad mmed[j] = medj make/d/o/n=(iHi(j)-iLo(j)+1) middle middle=abs(w-medj) mmad[j] = median(middle) make/d/o/n=(lx) sd sd[j]= mmad[j]/sqrt(2)/inverseErf(0.5) make/d/o/n=(lx) ki ki[j]= abs(imgraw[i][j]-mmed[j]) > nd*sd[j] make/d/o/n=(lx) yu if(ki[j]) yu[j] = mmed[j] else yu[j]= imgraw[i][j] endif imgraw_smth[i][j]=yu[j] endfor endfor killwaves w,temp,mmed,mmad,middle,sd,ki,yu end
A suggestion for the validity test is to compare results from your algorithm against those using posted code for other analysis packages (e.g. python).
As to the code itself, I offer these suggestions
--> replace for loops by implicit statements
--> use FREE waves, set waves outside loop when possible, and avoid making a wave just as a placeholder for a one step processing
October 11, 2023 at 08:50 am - Permalink
Disclaimer: I have not tested your code and I have no direct experience with this filter.
Suggestions:
1. it is not a good idea to have 6 Make statements inside an interior loop. As long as the dimensions of the waves remain fixed (with respect to the loop), you should create them (execute the Make statement) only once before getting into the loop. Note also that some of these waves, e.g., mmad and sd may be replaced by local variables.
2. it is not a good idea to keep computing in the inner loop
You should simply compute one scale factor e.g., 1/sqrt(2)/inverseERF(0.5) once before executing the loops.
October 11, 2023 at 11:12 am - Permalink
Thank you! I have compared my procedure with Matlab code and found they agree well. I used gnoise in Igor and copy the generated data into Matlab as orginal data and obtained the same filtered data using my Igor procedure and Matlab.
October 11, 2023 at 06:13 pm - Permalink
Just curious. Your procedure seems to be designed for image data. Is your test from a line profile on an image?
October 12, 2023 at 06:39 am - Permalink
In reply to Just curious. Your procedure… by jjweimer
I made a 1xN dimensional wave and applied my procedure and then did matrixtranspose to plot it.
October 12, 2023 at 05:10 pm - Permalink
FWIW, I believe your filter function will not work properly on 2-D images. When you input an MxN matrix, the function iterates over the M lines in a 1D manner, looking only along the N points in the single line for a median (average). To work with images, the function should instead iterate over each point location in the MxN image matrix, analyzing in both the x and the y directions to obtain a representative average (median) for the given point.
If all you want is a filter to work on 1-D waves, you might consider removing the loop on the additional dimension (and also for example renaming the input wave as vectorraw rather than imgraw).
Also, in Igor Pro matrix notations, a 1-D wave is a row vector and an (M x N) matrix has M rows and N columns. In MatLab matrix notations, a 1-D input is a column vector and an (M x N) matrix has M columns and N rows. See the discussion at the link below.
https://www.wavemetrics.com/forum/general/translating-matlab-matrix-mul…
October 14, 2023 at 08:16 am - Permalink
In reply to FWIW, I believe your filter… by jjweimer
Thanks.
October 15, 2023 at 06:58 pm - Permalink
