Quote character (") in strings
I get strings obtained from an api in json format for example
{"orbname":"20231004_000213.515_BE_UK"}\n{"orbname":"20231004_001652.467_UK"}\n
I want to extract all entries such as 20231004_000213.515_BE_UK etc
I have tried things like
    dummy = StringFromList(5,response,":")
    dummy = ReplaceString("orbname",response,"")
    dummy = ReplaceString("}\n{",dummy,";")
where response is the string from the api.
The problem with this is that the quote characters remains in the string.
How can quotes within a string be removed from the string?
Previously I have done this sort of thing by using a loop and search strings and
something like outputString = response[pos1,pos2] but am looking for a neater way
to do it perhaps with lists or similar.
I don't particualrly want get involved in json.
screen snip (25.91 KB)
A quote mark in a string must be escaped to survive as something other than the start or end of a string:
String junk="\"orbname\":\"something\""print junk
  "orbname":"something"print replacestring("\"orbname\"", junk, "")
  :"something"
Yeah- escaping quote marks can get pretty hairy if the strings will pass through multiple layers of interpretation. I've seen some pretty unreadable examples when composing a string to pass from Igor's command line to ExecuteScriptText, where both Igor and the OS are going to take a crack at interpreting quote marks.
DisplayHelpTopic "Escape Sequences in Strings"
Fortunately its not now proving too difficult for me.  The debugging view of strings seems quite accurate and helps.
