I have a file containing date&time (yy-mm-dd_hh-mm-ss) and a digital data (float). I could not plot it simply from menu Windows--New Graph. How do I plot it then? Thank you very much!
1) Convert your date & time text into regular date/time data. See here:
DisplayHelpTopic"Date/Time Waves"
For this you would need to convert your text wave with a small script, which is however not difficult. If your date/time information is equidistant, you could even use wave scaling and omit the x-wave altogether.
2) Use your date/time text data as tick labels. For this, create a plot just from the digital data, then open the Modify Axis dialog. Go to the Auto/Man Ticks tab and select User Ticks from Wave. There you can load your date/time data in. Note that this will create a tick for every point in your data, which might get too crowded in the graph. Read more here:
Thank you! I have tried both. As you said, second option shows too much ticks. For the first option, I plot the image shown below. How to remove the marked default year and date?
You have two options:
DisplayHelpTopic "Date/Time Waves"
DisplayHelpTopic "User Ticks from Waves"
April 27, 2023 at 03:50 am - Permalink
In reply to You have two options: 1)… by chozo
April 27, 2023 at 05:04 am - Permalink
Go to the Ticks and Grids tab inside the Modify Axis dialog and set Suppress Date for Date/Time Tick Labels.
April 27, 2023 at 05:46 pm - Permalink
You might even want to set the horizontal axis Time Format to Elapsed.
May 1, 2023 at 09:50 am - Permalink
