Radar (Spider) Plot
Mangum
Igor seems a little incomplete without the ability to generate radar plots: https://en.wikipedia.org/wiki/Radar_chart
I don't see this functionality anywhere so I am adding it to the wish list.
As far as I understand, radar plots are just polar plots with category labels?
You can access the polar plot package through Windows->New->Packages->Polar Graph
The angle wave you provide will determine how each category is spread around the circle, and you'll also need a text wave that provides the labels for each category. It looks like user-defined axis labels aren't allowed in polar plots at this point, so to hack our way into it you could run something like this:
String graphName
Wave/T/Z w
If(!WaveExists(w))
EndIf
DoWindow $graphName
If(!V_flag)
EndIf
//Get the boundaries of the prog axis layer draw commands
DrawAction/L=ProgAxes/W=$graphName getgroup=_all_
Variable endPos = V_endPos
Variable startPos = V_startPos
//Get the drawing code for the layer as well
DrawAction/L=ProgAxes/W=$graphName commands
SetDrawLayer/W=$graphName ProgAxes
Variable nCategories = DimSize(w,0)
Variable i, pos = 0, drawPos = strlen(S_recreation) - 1
//Loop through each category and remove the angle label, replacing it
//with the text in the category wave at the same x/y coordinates
For(i=0;i<nCategories;i+=1)
//Gets position of last draw command and its index
drawPos = strsearch(S_recreation,"DrawText",drawPos-1,3)
If(drawPos == -1)
continue
EndIf
//Get the end of line location after the DrawText call
Variable endOfLine = strsearch(S_recreation,"\r",drawPos)
If(endOfLine == -1)
continue
EndIf
//Get the location of the draw command from that drawtext call
pos = strsearch(S_recreation,"ITEMNO:",drawPos,3)
If(pos == -1)
continue
EndIf
//Extract the command index
String drawIndexStr = S_recreation[pos,drawPos]
Variable drawIndex = NumberByKey("ITEMNO",drawIndexStr,":",";")
//Full DrawText call with the x,y coordinates
String drawStr = S_recreation[drawPos,endOfLine]
//Get the coordinates used in the draw command
String locationStr = drawStr[strlen("DrawText "),strlen(drawStr)-1]
Variable xLoc = str2num(StringFromList(0,locationStr,","))
Variable yLoc = str2num(StringFromList(1,locationStr,","))
//Delete and replace the draw call
DrawAction/L=ProgAxes/W=$graphName delete=drawIndex,drawIndex
DrawAction/L=ProgAxes/W=$graphName beginInsert=drawIndex
DrawText/W=$graphName xLoc,yLoc,w[DimSize(w,0) - 1 - i]
DrawAction/L=ProgAxes/W=$graphName endInsert
EndFor
where graphName is the name of the graph window, and w is a text wave containing category labels that correspond to the angles in the angle wave.
The problem is that the original angles will be redrawn every time you adjust the graph size, etc., so I would only run the category label code once you're ready to export the graphic as an image. You could probably trigger this code through a window resize hook to get around that problem though.
March 10, 2023 at 11:23 am - Permalink
FYI, From the 9.02 Beta1 release announcement at https://www.wavemetrics.com/news/igor-pro-902-beta-1-released
Radar Chart.ipf:
New Radar and Spider Chart package. See Radar Chart Procedure for help.
March 13, 2023 at 05:53 pm - Permalink
