Issuing commands from a terminal
Working on a workflow where Igor loads and fits data and returns a file with fitted parameters. I have something working but wanted to double check on the formatting of the terminal level command. Within Igor from the command line I can issue
process_data("Path_toFile")
all works as expected
In terminal (on a Mac in this case) the command issued looks like this
"Path_To_igor" /X 'process_data("Path_toFile")'
Note the quotations around the command issued. Process_data(string input) is a function I wrote that runs the internal workings.
If I omit the quotations around the command, I get an error
"invalid mode specification"
However when testing initially for the connection to Igor from the terminal I used:
"Path_To_igor" /X beep
or
"Path_To_igor" /X make lucy
Notice no quotations around the command even the name of the wave to be created
Is this expected behavior and if so what is the decision factor on whether to have quoted commands or not?
does the first single quote act as an escape for the double quotes around Path_toFile?
so
doesn't need quotes, but
"Path_To_igor" /X 'make $"lucy"'
does?
February 17, 2023 at 01:46 am - Permalink
My path to Igor on the Mac is
'/Applications/Igor Pro 9 Folder/Igor64.app/Contents/MacOS/Igor64' and the quotes are needed because of the spaces in the path name that would otherwise confuse the shell script.
If I issue this command to make a wave of length 12 named lucy
'/Applications/Igor Pro 9 Folder/Igor64.app/Contents/MacOS/Igor64' /x make /n=12 lucy
This works and the history window shows this
If however I issue the standard time() command
'/Applications/Igor Pro 9 Folder/Igor64.app/Contents/MacOS/Igor64' /x time()
The zsh shell script seems to take over and I get a new prompt in the terminal
function>
instead of the previous
(base) andreashegedus@Andys-iMac ~ %
control-c gets you back to the usual prompt.
Now if I issue this simple print command
'/Applications/Igor Pro 9 Folder/Igor64.app/Contents/MacOS/Igor64' /x print("hello World")
I get an error:
zsh: unknown file attribute: h
If I recast the print command to have quotes around it - note single quotes
'/Applications/Igor Pro 9 Folder/Igor64.app/Contents/MacOS/Igor64' /x 'print("hello World")'
This works with both the command and result being printed
At this stage I think it is not an Igor issue but rather a zsh shell script issue and the going forward plan is to encapsulate everything in quotes.
February 17, 2023 at 08:05 am - Permalink
If you don't do anything else, the double quotes are interpreted by the shell. If I issue this command in terminal:
/Applications/Igors/Igor\ Pro\ 9.01\ Folder/Igor64.app/Contents/MacOS/Igor64 /X print "Hello"
Igor starts up, but I get this error:
Note that the command lacks the quotes, which were interpreted and removed by the shell.
If I use this command (note escaped quotes):
/Applications/Igors/Igor\ Pro\ 9.01\ Folder/Igor64.app/Contents/MacOS/Igor64 /X print \"Hello\"
I get what I wanted: Igor prints Hello into the history.
I could also use single quotes around the entire command string- that tells the shell that it shouldn't try to interpret anything within the command string.
February 17, 2023 at 09:34 am - Permalink
