How can I batch export graphs using graph title
Hi!
I want to export multiple graphs into png and name them based on their title. I found an macro online but it generate error saying "expected right parenthesis
". Can you correct this error for me? I really appreciate!
//Gmv1 Save all graphs as png //Saves all graphs in experiment as PDF files in the //same folder as the experiment or in subfolder called "graphs" Function SaveAllGraphs() variable NGraphs, i string graphList, alertStr, currWindow GraphList = WinList("*", ";", "WIN:1") graphList = RemoveFromList("SnglMove", graphList) NGraphs = itemsInList(GraphList) string homePathStr, graphPathStr pathInfo home homePathStr = S_path graphPathStr = homePathStr + "graphs" newPath /O graphs, graphPathStr print "will save graphs for all runs in " + graphPathStr for (i = 0; i < NGraphs; i += 1) currWindow = stringFromList(i, graphList) doWindow /F $currWindow saveGraph() endFor End //SaveAllGraphs //Save top window graph using its window's name //Top window must be a graph. Graph you want to save must be top window //Graph is saved as pdf file in folder called "graphs" in the home path (folder //of the current igor experiment), which you can create in advance or in response to the dialog //box that appears if "graphs" does not exist. //Filename is created from igor experiment name and graph window's title Function saveGraph() string windowTitleStr, titleFirstWord //Obtain window's title's first word, to be used as part of the filename //e.g., if autonamed graph1:y vs x, then extract "graph1" getWindow kwTopWin, wtitle //(I am getting title because I don't know how to get the window's name) windowTitleStr = S_Value titleFirstWord = stringFromList(0, windowTitleStr, ":") string exptName, fName exptName = igorInfo(1) fName = titleFirstWord + "_" + exptName print "windowTitleStr", windowTitleStr print "titleFirstWord", titleFirstWord print "fName", fName string alertStr alertStr = "Will try to save graph with title " + windowTitleStr alertStr += " as a pdf file in same folder as present Igor" alertStr += " experiment, \nusing name " + fName doWindow /H /F print alertStr SavePICT/Z/O/P=graphs/E=-5/RES=300 as fName //Here save to png with resolution 300 ppi //SavePICT /Z/O/P=graphs/E=-2/W=(0,0,0,0) as fName if (V_flag == 0) alertStr = "Graph saved successfully." else alertStr = "***An error occurred. Graph not saved" endIf print alertStr End //saveGraph()
note that files will be overwritten using the /O flag
November 22, 2022 at 06:04 am - Permalink
