Matrix calculations
duli
I am new to Igor Pro and I want to make matrices and do calculations by using these matrices.
I can handle with matrices which have real, known elements.but the problem is,I have matrices with imaginery elements too.
Again I have unknown variables.
As an example I have to do,
[ x-iy y+iz ][ x-iz g+id] [ a-iy b+iz]
[a-ib c+id] * [a-ia a+ih] +[x-ih c+iz ]
I need the final answer from these variables.
How can I write procedures for such calculations
Thanks
Duli
Normal matrices can be real or complex but they always have real indices. As such, an index in bracket could not be complex and should evaluate to a single number. Your expression [ x-iy y+iz ] is both complex and not very meaningful unless you missed some operator between the two y's.
To be able to help you better I'd need to know the precise mathematical expressions that you are trying to evaluate.
August 9, 2010 at 09:46 am - Permalink
Ok I will write my matrix as this way.
MatA ={{ x-iy, y+iz},{a-ib c+id}}
(That means; MatA is a 2x2 matrix; MatA[1,1]=x-iy, MatA[1,2]=y+iz, MatA[2,1]=a-ib, MatA[2,2]=c+id
MatB ={{x-iz, g+id},{a-ia, a+ih}}
MatC={{a-iy, b+iz},{x-ih, c+iz }
I want to get the MatA*MatB+MatC
I am sorry for the bad explanation in the previous post
Thanks
August 9, 2010 at 12:06 pm - Permalink
Then you should execute:
Make/C/D/N=(2,2) MatA={{cmplx(x,-y),cmplx(a,-b)},{cmplx(y,z),cmplx(c,d)}}
Similarly for MatB and MatC.
To get the expression MatA*MatB+MatC
MatrixOP/O result=MatA x MatB +MatC
I hope this helps,
August 9, 2010 at 02:03 pm - Permalink
Variable i=cmplx(0,1)
then you can write expressions such as
Make/C/D/N=(2,2) MatA={{x-i*y, a-i*b}, {y+i*z, c+i*d}}
which I find easier to read
John Bechhoefer
Department of Physics
Simon Fraser University
Burnaby, BC, Canada
August 9, 2010 at 08:08 pm - Permalink
