How to view z axis of 3d image cube with cursor
tejiang.cug
Hello everyone,
I am analyzing a 3d image cube, with (rows, columns, layers) representing (X location, Y location, wavelength), respectively. In ENVI, you can open an image and use cursor to pick pixel at specific location (XX and YY), and then there is another window showing the spectral profile (plotting of Z axis values vs wavelength). This is really convenient. I was wondering if I can achieve it in Igor. Now I only know I can preview the layer of 3d wave in data browser. Thank you very much!
You could program it. You could make a panel with two subwindows separated by a frame guide down the middle. Subwindow one will show a 2D XY image at a specified wavelength and subwindow two your 1D spectrum. Use Ctrl+i to place a cursor on the image and make a button which updates the 1D spectrum, or if you want the fancy version a hook function that runs when the cursor is moved.
Have you done any programming in Igor already?
October 10, 2022 at 08:03 am - Permalink
The Image Processing Demo experiment has a 3-views panel for visualizing 3D volumes.
File->Examples->Imaging->Image Processing Demo.
October 10, 2022 at 09:05 am - Permalink
In reply to The Image Processing Demo… by JimProuty
Hello JimProuty,
Thank you for your suggestions. I have tried your method, but I found these three Line profiles are still in the horizontal direction, none of them are showing the z profile.
For example, I made a 3d wave, test, and define the values equal r. Then if one of the profile are showing z axis, it should not be a horizontal line.
Please let me know if I can change the direction of the red line. Thank you.
October 11, 2022 at 04:55 am - Permalink
In reply to You could program it. You… by olelytken
Hello olelytken,
Thank you very much! I will try your method today.
I have some experience on programming in Igor. I was trying to find if the Igor have build in function can achieve this, now I think maybe I should make it myself. Thanks.
October 11, 2022 at 04:57 am - Permalink
Here is something that might help.
wave cube
// create image from cube, e.g. using sumBeams
MatrixOP/O M_SumImage = sumBeams(cube)
DoWindow/F CubeImage
if (V_flag == 0)
NewImage/K=1/N=CubeImage M_SumImage
SetWindow CubeImage,hook(s)=HookFunc
Function HookFunc(s)
STRUCT WMWinHookStruct &s
wave/Z cube
wave/Z M_SumImage
if(!WaveExists(cube) || !WaveExists(M_SumImage))
// where is the mouse?
variable xx = round(AxisValFromPixel("", "Bottom", s.mouseLoc.h))
variable yy = round(AxisValFromPixel("", "Left", s.mouseLoc.v))
variable maxX = DimSize(cube, 0)
variable maxY = DimSize(cube, 1)
switch(s.eventCode)
case 3: // handle left mouse click
// prevent error when clicking outside of image
if (xx >= maxX || yy >= maxY || xx < 0 || yy < 0)
break
// extract spectrm
MatrixOp/O CrsSpec = beam(cube, xx, yy)
DoWindow/F Spectrum
if (V_flag==0)
Display/K=1/N=Spectrum CrsSpec
break
endswitch
return 1
If you execute "DisplaySumImage(cube)", where cube represents your spectral image wave, you'll get a "sum-image" as 2D representation, then clicking into it will show the spectrum at that location. Note that the spectrum is not yet scaled to energy.
October 11, 2022 at 05:23 am - Permalink
In reply to Here is something that might… by ChrLie
Hello ChrLie,
Many thanks to your help! I found I was repeating the question already posted (https://www.wavemetrics.com/node/21126).
Best
Jiang
October 11, 2022 at 09:11 am - Permalink
