Using Funcfit with constrains
IVP
Hi. How can I use /C to add constrains to a custom fitting function?
If I follow the example from "Fitting with Constraints" I get an error saying "expecting fitting function".
Thanks.
Can you post the command you are trying to execute? This error does not sound like some problem with constraints but rather a syntax error. Maybe you don't have the /C flag after your input wave? We need a bit more information to judge what is going on.
October 2, 2022 at 02:03 am - Permalink
The error I am getting is at /C saying "Expected fitting function"
Thanks.
October 3, 2022 at 06:03 am - Permalink
This should work. /C must be behind the MyFitFunc W_coef MyFitWave
October 3, 2022 at 07:02 am - Permalink
Thank you ilavsky. It worked!
October 3, 2022 at 07:36 am - Permalink
