Load User Procedures from Menu
I have a very simple question to ask.
I have a bunch of self-written procedures saved in User Procedures folder. I don't want to use them as global procedures as they are slowing down initialization/startup of Igor and also not all of them are required for a single experiment.
Instead, I am having a global procedures (saved in Igor Procedures folder) which will create a new Menu containing items which should load corresponding procedures from User Procedures folder.
I have tried the following two methods but none of them are working.
Method 1:
Menu  "My Procedures"
"Procedure 1", loadproc(1)
"Procedure 2", loadproc(2)
Function loadproc()
Variable indx
if(indx==1)
#include "Procedure 1"
elseif(indx==2)
#include "Procedure 2"
Method 2:
"Procedure 1", #include "Procedure 1"
"Procedure 2", #include "Procedure 2"
From the manual, what I understand is #include will only work before starting any function in a procedure and also found working in such a way.
Can someone help me out how to solve this problem?
Thanks a lot in advance.
SS
There are various solutions to this. Procedure loader is a good one and it is "done" for you.
Most basic is to use your method 2 but call a function (in the same procedure file) which has
        Execute/P "INSERTINCLUDE \"YourFileWithIncludes\""
        Execute/P "COMPILEPROCEDURES "
of a file "YourFileWithIncludes.ipf" located in User Procedures. This YourFileWithIncludes.ipf contains rest of #include lines you need.
Already tried before posting, but Procedure Loader did not worked for me as I am using an older version (6).
However, the solution provided by ilavsky worked for me.
Thanks again  :-)
SS
The problem with your solution is that any command that starts with pound sign ("#") is a compiler directive, not a run-time command. As noted by @ilavsky, the solution is the Execute/P command, which has the power to add compiler directives to the main procedure window, and then trigger a compile.
