wave subtraction
ahmed.shaaban86
Dear Community,
Sorry that I am new here and I have too many questions. I have a wave that has 10 values. I want to subtract each value inside the wave from the value that is before it (except the first point), so point 2 - point1, point 3- point 2 and so on .. and finally have these new values in a new wave or to substitute the original wave.
Is there a way of doing that?
Many thanks in advance!
Look up differentiate function.
June 2, 2022 at 07:15 am - Permalink
Differentiate does something a bit more complex than what the OP was asking for. It's quite possible that Differentiate is really what they want. However,...
For a wave called "wave0":
You have to decide what goes into wave0dif[0].
Read more: DisplayHelpTopic "Waveform Arithmetic and Assignment"
June 2, 2022 at 09:18 am - Permalink
I would strongly urge you to do the Guided Tour, which is part of the Getting Started help (Help->Getting Started). It takes a bit of time, but will save you more time in the future.
June 2, 2022 at 09:19 am - Permalink
Dear all,
Thank you very much for the valuable input. Actually both approaches worked for me except that when I used the differentiate function, I ran into the problem that the first point was always omitted for some reason.
I tried to play around with the differentiate function but I could not find a way to retain the first value in the wave.
The second method (wave0dif[1,] = wave0[p] - wave0[p-1]) worked fine.
I will do the guided tour and I think it is very helpful as a kick start. Many more thanks for the great help.
June 3, 2022 at 01:24 am - Permalink
Differentiate/METH=1 does a forward difference, what you originally asked for was a backward difference. The forward difference is equivalent to this (I called my wave "junk"):
Except for the treatment of the last point. Note that the difference isn't performed for the last point in the wave because junk[p+1] is out of range for the last point. Differentiate/EP=1 *deletes* that last point, /EP=0 *approximates* it. The approximation that is applied is to do a backward difference for that last point.
If you use /METH=2, you get what I originally posted, except for the *first* point. In that case, the difference goes into the destination starting at point 1, not point 0. The approximation that Differentiate applies is to use a forward difference for the first point, my example simply left the first point in place.
June 3, 2022 at 09:35 am - Permalink
