WAVE/Z vs /ZZ
thomas_braun
I've been playing around with the new WAVE/ZZ flag in IP9.
Example code:
Function/WAVE GetNullWave() return $"" End Function MakeWave() Make/O data End Function Dostuff() MakeWave() WAVE/Z data = I_DONT_EXIST print 1, WaveExists(data) WaveClear data WAVE/ZZ data = I_DONT_EXIST print 2, WaveExists(data) WAveClear data WAVE/Z data print 3, WaveExists(data) WaveClear data WAVE/ZZ data print 4, WaveExists(data) WAveClear data WAVE/Z data = GetNullWave() print 5, WaveExists(data) WaveClear data WAVE/ZZ data = GetNullWave() print 6, WaveExists(data) WAveClear data End
This gives:
•dostuff()
1 0
2 0
3 1
4 0
5 0
6 0
So I would say that /ZZ is always better than /Z as picking up global waves is suprising. Is that correct?
The documentation for WAVE makes it very clear that if you provide LocalName without =pathToWave Igor will "[make] the connection between the local name and the actual wave". If you consider the documented behavior to be surprising then using /ZZ might be useful but it will require more verbose WAVE statements than necessary in some situations (you might even consider that to be an advantage).
Here is an example in which you would not want to use /ZZ:
If you insist on using /ZZ, you can easily rewrite that like this:
the later is slightly more verbose and might be considered more difficult to read.
The intent when adding the /ZZ flag was to make it possible to avoid the potentially expensive cost of runtime lookup by name in code that is very performance sensitive.
May 3, 2022 at 08:40 am - Permalink
Good, point. So I have to use /Z when I want to pickup global waves as in:
Not really a suprise re-reading the documentation.
May 3, 2022 at 10:00 am - Permalink
In Igor 8 and later, the cost to look up a wave in the current data folder is not that large, especially given the inherent overhead of running user code. But there is some cost.
Well, in your example, you can be reasonably confident that WaveStats/W will create the wave, so the /Z isn't strictly necessary as the lookup is very unlikely to fail. And in fact, it would be sufficiently surprising that you might want the error that lets you know about it. If you use /Z, though, it is expected that you will follow up with a call to WaveExists() since the /Z flag indicates that there is a reasonable chance that the lookup will fail.
May 3, 2022 at 12:07 pm - Permalink
