making a Pressure -Temperature-Concentration phase diagram
Leon
1) Is there is an easier way to build a 3D diagram ( P-T-X ) in Igor Pro: if so which one?
because for the moment the only one I have found is this Gizmo.
2) I have a path located x=10, 20, 30 planes in a Gizmo plot.
Question is, how to fill the area between this path, to have something that looks like in figure
Thanks
I think you need to give us a bit more information about what you're trying to achieve.
In the figure there are points, paths and surfaces. It sounds like you have some points and want to construct surfaces. How that should be done depends on what you know about your data. If you don't care about the thermodynamics you may be looking for some kind of 'best fit' or triangulated surface, otherwise you may have some appropriate function to describe the surface.
April 8, 2022 at 03:03 am - Permalink
Hello Leon,
Feel free to send a sample experiment to support@wavemetrics.com and I'll help you with the Gizmo plot.
April 8, 2022 at 12:26 pm - Permalink
