Syntax Highlighting in VIM
thomas_braun
Based on the work of Peter Li, http://www.hcs.harvard.edu/~pli/code/#vim, I completely revised the syntax highlighting for Igor Pro procedures in Vim.
Install into a folder read by vim [1] and add the following code to vimrc
" add filetype detection for Igor Pro procedure files
au BufNewFile,BufRead *.ipf set filetype=igorpro
" Honour user settings for colors or use the default igor pro colors
" let igorpro_default_colors = 1
" If you want to use folding, activate it with
" set foldmethod=syntax
[1]: https://vim.fandom.com/wiki/Creating_your_own_syntax_files#Install_the_…
Project Homepage: | View Homepage |
Syntax Highlighting in VIM IGOR.6.30.x-0.41
Release File: | vim-igorpro-v0.41.tar.gz (17.15 KB) |
Version: | IGOR.6.30.x-0.41 |
Version Date: | |
Version Major: | 0 |
Version Patch Level: | 41 |
OS Compatibility: | Windows Mac-Intel |
Release Notes: |
Lots of changes for Igor Pro 7 |
What do you mean by "a folder read by gVim"? I just started Vim, so I'm pretty ignorant.
Also, does that entire code snippet really go into vimrc? I'm surprised to see things like
in code.March 31, 2022 at 12:22 pm - Permalink
I've adapted the description as it was reflowed incorrectly. The " is the comment sign in vimL.
I also suggest to try the version from github as that is much more recent.
April 1, 2022 at 04:39 am - Permalink
