Curve fitting to NaN for certain x-values
Hello Igor users, I am trying to fit a user-built three-exponential function to a data set to extract kinetic information. The curve fit dialog is below:
Function THIRDSTATE(w,X) : FitFunc
    Wave w
    Variable X
    //CurveFitDialog/ Equation:
    //CurveFitDialog/ f(X) = A3*((ERFEXP(KB,D,(1/(K1+K2+K3+(K1*4))),X)*(K1+K2+K3+(K1*4)))*K1*K2*(ERFEXP(KB,D,(1/(-K2-K3)),X)*(K2-K3)+ERFEXP(KB,D,(1/(-K1-K2-(K1*4))),X)*(K1-K2+(K1*4))-ERFEXP(KB,D,(1/(-K1-K3-(K1*4))),X)*(K1-K3+(K1*4)))/((K2-K3)*(K2-K1*(1+4))*(K3-K1*(1+4))))+\
    //CurveFitDialog/ OS
    //CurveFitDialog/ X
    //CurveFitDialog/ Coefficients 7
    //CurveFitDialog/ w[0] = KB
    //CurveFitDialog/ w[1] = D
    //CurveFitDialog/ w[2] = OS
    //CurveFitDialog/ w[3] = A3
    //CurveFitDialog/ w[4] = K1
    //CurveFitDialog/ w[5] = K2
    //CurveFitDialog/ w[6] = K3
    return w[3]*((ERFEXP(w[0],w[1],(1/(w[4]+w[5]+w[6]+(w[4]*4))),X)*(w[4]+w[5]+w[6]+(w[4]*4)))*w[4]*w[5]*(ERFEXP(w[0],w[1],(1/(-w[5]-w[6])),X)*(w[5]-w[6])+ERFEXP(w[0],w[1],(1/(-w[4]-w[5]-(w[4]*4))),X)*(w[4]-w[5]+(w[4]*4))-ERFEXP(w[0],w[1],(1/(-w[4]-w[6]-(w[4]*4))),X)*(w[4]-w[6]+(w[4]*4)))/((w[5]-w[6])*(w[5]-w[4]*(1+4))*(w[6]-w[4]*(1+4))))+w[2]
The x-data runs from -50 to 4000 (time) and the function yields "NaN" at about 250 (note the x-data is not evenly spaced, the steps are close together close to zero and get farther apart farther from zero). I do not think I am generating 0/0 in the fit and I can't quite figure out where my bug is.
Note that "erfexp" is a user-designed exponential function that is the convolution of an error function with a Gaussian, KB is the gaussian FWHM, D is "time zero", A3 is an amplitude, and the k's are rate constants. Do you have any debugging suggestions? Many thanks!
I would add a debugging section to catch the NaN in ERFEXP, like this:
Function ERFEXP(Variable w0,Variable w1,Variable w2, Variable xx)
    if( numtype(w0) != 0 || numtype(w1) != 0 || numtype(w2) != 0 || numtype(xx) != 0 )
        Debugger
    Variable result = ... your code here
    if( numtype(result) != 0 )
        Debugger
    return result
Then look at the coefficients in the calling routine (THIRDSTATE) to see who's to blame.
It's hard for my eyes and brain to understand such a long complicated expression. I would be tempted to break it up into multiple terms assigned to variables, and then combine those terms in a shorter, simpler expression. It looks to me like you have a situation where you are multiplying one ERFEXP() by another and another. Your description sounds like they should be added? But as I said, I can't really parse that expression without a lot of pain :)
I would also add a similar catcher in THIRDSTATE, like this, just in case something in that expression is at fault.
    Variable result = w[3]*((ERFEXP(w[0],w[1],...
    if (numtype(result))
        Debugger
    return result
The Curve Fitting dialog won't care about the extra code (though you might see it when it shows you the function).
Both erf() and Gauss() are well-behaved for large values of X (in both directions), but you don't show us what's in ERFEXP(), so we can"t tell if erf() and gauss() might be combined in a bad way.
The exp() function itself will overflow at fairly modest values of X.
