HELP! how to load N images (loop) and fit, then plot fit results from all images in one curve
VL2008
So that to see how the fit is changing with every image. For example a center coordianates of a gaussian fit move linearly in one direction and I would get a straight line.
Can anybody please advise me on how to start writnig this code I am new to IGOR?
I can fit but I don't know how to open files one by one by looping its name?
On Igor's command line, execute this command to see an example of code to do multiple fits in a loop:
DisplayHelpTopic "Batch Fitting"
To see an example of loading multiple files:
DisplayHelpTopic "Loading Waves Using Igor Procedures"
That material includes example code for loading all the files in a folder. You will need to combine the examples to do batch fitting of data loaded from files on disk.
May 1, 2008 at 11:38 am - Permalink
Some general suggestions:
1) break the task into separate parts
You can find hints for each part in the tutorials, manual, and here.
2) test each function on data where you know the results before hand
3) create and test a function to do the first two parts
4) create and test a loop function
5) add the final analysis
HTH
May 1, 2008 at 01:18 pm - Permalink
May 12, 2008 at 07:40 am - Permalink
