I want to make an axis with the numbers directly adjacent to the left or right of the tic marks on the X axis. I can't seem to find any setting like this. I have attached a screenshot example of what the axis looks like in another program.
I found no way to laterally offset tick labels and align them as shown, so there is no simple setting to do this. You could fake it of course by using the text tool to label each tick manually or with a small script. I have attached an example of this. Of course, using the text tool is way less flexible than normal axis label, but if you write a small script for this you could easily update the tick labels to adapt for changing tick positions. Otherwise, I guess you will have to wait until WM adds support for lateral tick label offsets.
Here is a *very* bare-bones Igor function that will do something like that:
Function OffsetTickLabels(String gname, Wave tickvals, Wave/T ticklabels)Variable nticks = numpnts(tickvals)Variableiif(strlen(gname) == 0)
gname = WinName(0,1)endifSetDrawLayer progfront
// Erase any previous axis drawn by this functionDrawAction/W=$gname getgroup=SpecialTickGroup, delete
// start a named group so that it can be erasedSetDrawEnv/W=$gname gstart, gname=SpecialTickGroup
// "axrel" coordinates are 0-1 coordinates that span the rectangle// inside the axesSetDrawEnv/W=$gname xcoord=axrel, ycoord=axrel
// The axis lineDrawLine/W=$gname0,1,1,1for(i = 0; i< nticks; i++)Variable value = tickvals[i]// Draw a tick line: Using xcoord=bottom so that we can specify// the tick positions in data values// The hard-coded values 1.01 and 1.1 should be adjustable input options!SetDrawEnv/W=$gname xcoord=bottom, ycoord=axrel
DrawLine/W=$gname value, 1.01, value, 1.1// Draw the tick labels, rotated by 90. That should be an option.// The hard-coded 0.8 and 1.1 should be optionsSetDrawEnv/W=$gname textrot = 90, xcoord=bottom, ycoord=axrel
DrawText/W=$gname0.8*value, 1.1, tickLabels[i]endforSetDrawEnv/W=$gname gstop
It takes a graph name string which can be "" to use the top graph window, a numeric wave full of axis values where you want the ticks, and a text wave full of corresponding labels.
The drawing is done using the ProgFront draw layer. It makes a named group drawing object so that it can erase any previous drawing done by a previous invocation of the function.
Ways in which this is deficient:
It should take an input that sets the offset between the tick and tick label
It should take an input that sets the length of the tick lines
It should take an input that specifies which axis to use (note that the X coordinates here are set to "bottom" to use the bottom axis)
September 27, 2021 at 11:38 am - Permalink
September 27, 2021 at 12:54 pm - Permalink
I probably should post my test experiment file, too.
September 27, 2021 at 12:55 pm - Permalink
Thank you all, I really appreciate it! I'll give it a go.
September 27, 2021 at 01:36 pm - Permalink
