Reading Header and Data From The Same File
hrodstein
// ReadHeaderAndData(pathName, fileName, extension)
// Demonstrates how to open a data file to read header information using FReadLine
// and then to load data from the file using LoadWave.
// If pathName and fileName are not empty, they are expected to point to the data
// file which will be loaded without any dialog.
// If either pathName or fileName is empty (""), an Open File dialog is displayed.
// If you are not familiar with symbolic paths, execute this:
// DisplayHelpTopic "Symbolic Paths"
Function ReadHeaderAndData(pathName, fileName, extension)
String pathName // Name of symbolic path or "" to display dialog.
String fileName // Name of file or "" to display dialog. Can also be full or partial path relative to symbolic path.
String extension // e.g., ".dat" for .dat files. "????" for all files.
Variable refNum
// Possibly display Open File dialog.
if ((strlen(pathName)==0) || (strlen(fileName)==0))
Open /D /R /P=$pathName /T=(extension) refNum as fileName
fileName = S_fileName // S_fileName is set by Open/D
if (strlen(fileName) == 0) // User cancelled?
return -1
// fileName is now a full path to the file.
// Read the header lines
Open /P=$pathName /R refNum as fileName
// Read header here using FReadLine
Close refNum
LoadWave/J/P=$pathName fileName
Variable refNum
return -1
Close refNum
For a fleshed-out example see http://www.igorexchange.com/node/5842#comment-9728
Here are some simple examples of loading header and data from the same file:
https://www.wavemetrics.com/code-snippet/reading-xps-header-and-data-sa…
https://www.wavemetrics.com/code-snippet/read-patient-header-and-data-s…
September 13, 2021 at 01:32 pm - Permalink
