NI VISA Driver for Mac OS 10.15 (Catalina)
This post is of interest if you run the VISA XOP on Macintosh.
VISA (Virtual Instrument Software Architecture) is a system that provides instrument control via serial ports, GPIB, Ethernet, USBTMC and other media.
Igor's VISA XOP relies on a VISA library. Most people use the National Instruments library named NI-VISA.
National Instruments recently released version 20.0.0 of the NI-VISA for Macintosh. This is the first version that supports Mac OS 10.15 (Catalina).
I successfully installed and tested NI-VISA 20.0.0 on Mac OS 10.15 (Catalina) and Mac OS 11.0 (Big Sur) beta 4. However, installing the library required jumping through hoops. The following describes what I did. Your experience may be different.
- Download the latest NI-VISA library for Macintosh.
As of this writing, this produces a file named NI-VISA_Full_20.0.0.pkg. - Double-click NI-VISA_Full_20.0.0.pkg.
Mac OS displays a dialog saying "NI-VISA_Full_20.0.0.pkg can’t be opened because Apple cannot check it for malicious software". - Click OK.
- Open System Preferences, enter the Security & Privacy section, and click the General tab.
It says "NI-VISA_Full_2.0.0.pkg" was blocked from use because it is not from a identified developer". - Click Open Anyway.
NI-VISA_Full_20.0.0.pkg runs again. Again, Mac OS says "NI-VISA_Full_20.0.0.pkg can’t be opened because Apple cannot check it for malicious software". - Click the Open button and proceed with the installer as usual finally clicking Install.
The installer goes about 90% through the installation process. Then a dialog appears saying "System Extension Blocked - A program tried to load new system extension(s) signed by “National Instruments. If you want to enable these extensions, open Security & Privacy System Preferences." - Open System Preferences, enter the Security & Privacy section, and click the General tab.
It says "System software from developer National Instruments was blocked from loading". - Unlock the dialog by clicking the lock icon and entering your password.
- Click Allow.
A dialog appears saying "Legacy System Extension - Existing software on your system loaded a system extension signed by National Instruments which will be incompatible with a future version of macOS. Contact the developer for support." - Click OK.
The NI-VISA installer says "Registering updated components" and shows no progress for a minute or two. Then the NI-VISA installation completes. - Restart the machine.
When I restarted the machine, the restart failed and the machine displayed a circle with a bar through it. I then pressed the startup button for six seconds causing the machine to shut down. I then restarted while pressing the option key and selected my boot drive, and the machine started successfully. I then successfully tested the VISA XOP using a USB-to-Serial adapter.
Update: As of Mac OS 11.4, we experience crashes when trying to access the NI-VISA library via the VISA XOP using the current NI-VISA version 21.0.
August 25, 2021 at 05:48 am - Permalink
Update: I have added a post with instructions for running NI-VISA on Mac OS 12.5 here. The instructions will probably work on Mac OS 11.4 through 12.x.
August 5, 2022 at 04:09 pm - Permalink
