Help with zero offset
Hi all, I have an issue I can't wrap my head around at the moment, and can't find suitable answers I can piece code together from on here.
I have datasets which have depth sensor data, the animal regularly returns to the surface of the water but cannot be above the water.
There is 0.5m allowance on the sensor resolution but one data set has a 22m offset which drifts over time to -3.5m offset.
The data is sampled every 5 seconds starting 2015-04-14 11:10:00 for approx 6 months. Sample attached and short clip here:
Depth,Temperature,Light_Level
112.5,23.25,127
113.5,23.25,127
113,23.25,127
112.5,23.299999,127
111.5,23.299999,127
111.5,23.299999,126
111,23.35,126
110,23.35,126
109.5,23.35,128
109.5,23.400002,129
108.5,23.450001,129
108,23.549999,129
I want to use a 3 day moving average of minimum depth calculated each day (which should be 0) to correct the depth data points by the moving average.
The final step would then be to turn all remaining negative values to 0 so no data is above the surface of the water.
Any help would be much appreciated
graph of drift on depth sensor over time sample of the dataset (4.04 MB)
This would be one way of doing it:
Function MyFunction()
    //  Creates a dummy wave with some values
    Make/O/N=1000 DepthWave=enoise(1)+100/(p+10)+1
    //  The size of the running average box. The actual size of the box will be 1+3*2 = 7 in this case
    Variable BoxSize=3
    //  Calculates a running minimum value using the specified box size. The Min and Max are used to prevent out-of-bounds values
     Make/O/N=1000 MinDepthWave=WaveMin(DepthWave, Max(0, p-BoxSize), Min(999, p+BoxSize))
     // Displays the results
     Display DepthWave, MinDepthWave
     ModifyGraph rgb(MinDepthWave)=(0,0,65280)
You could also use a for loop or maybe even MatrixOP. There are many options.
Make/O/N=1000 MinDepthWave=WaveMin(DepthWave, p-BoxSize, p+BoxSize)
It might be easier to understand like this, but like this it will try to access points before 0 and after 999 and therefore crash. The messier looking version with Min() and Max() prevents that.
In reply to by olelytken
Hi olelytken,
Thanks for your response. I've run your code and it works for the dummy wave, then modified for my depth wave. After a long painful afternoon of problem solving, I have a working solution.
I had to convert my date&time wave into numerical, make the start point 0 and set the scaling to 1, then reconvert after making the box into date&time and adjust the scaling & start point back.
Function MyFunk()
    //  Converts the wave scaling from Date&time to numeric with delta 1
    SetScale/P x 0,1,"", Depth
    //  The size of the running average box. The actual size of the box will be 17,280*3 = 51,840 (number of points in 3 days at 5 seconds frequency)
    Variable BoxSize=51840
    Make/O/N=(DimSize(Depth, 0)) MinDepthWave_3day=WaveMin(Depth, p-BoxSize, p+BoxSize)
    //  Converts the wave scaling back from numeric to Date&time with delta 5
    SetScale/P x 3511822200,5,"dat", Depth,MinDepthWave_3day;DelayUpdate
    SetScale d 0,0,"Meters", Depth,MinDepthWave_3day
    Display Depth, MinDepthWave_3day
    ModifyGraph rgb(MinDepthWave_3day)=(0,0,65280)
    SetAxis/A/R left
I didn't get any warnings or issues with out-of-bounds using the shorter code, so just stuck with it for simplicity and used DimSize to give the N value for the depth wave.
Is there a way to read the scaling, '3511822200' and delta '5' value from the wave, so i can automate that for all datasets also?
Many thanks
You can look at the help for WaveMin to see how to convert between X and points. You can also look at the help for DimDelta and DimOffset
Thanks, appreciate the help and the directions on where to look. Works very nicely, I'm not 100% sure on the calculations behind it but it gives me a great min depth wave which I can use along with the wave arithmetic panel to correct the depth wave drift back to 0 for both positive and negative numbers.
I am still confused by your writing for box size though, you wrote 'The actual size of the box will be 1+3*2 = 7 in this case
    Variable BoxSize=3' I don't understand where your calculation came from, I understand you were working on a numerical wave case but still don't see where 7 came from, and then you put 3 on the variable. What am I missing?
Thanks
The WaveMin() calculation is done for each point in MinDepthWave_3day. Let's consider point 10 in MinDepthWave_3day as an example: Point 10 will be calculated as WaveMin(Depth, 10-BoxSize, 10+BoxSite) = WaveMin(Depth, 7, 13) meaning the smallest number of seven points: 7,8,9,10,11,12,13.
So, the final stage, I looked at the data and chose a 6 hour wave to best represent the minimum depth values. I created a 6 hourly mean from that minimum depth wave to smooth it, and use the wave arithmetic panel to subtract it from the main depth wave, thereby correcting the offset back to zero.
The final stage is now to remove the few anomalies which are still less than 0. Is there a function for something like this, smoothing? or would I have to write a for loop that replaces any negative value with 0?
corrected depth graph (60.51 KB)
To change all negative values to 0 you could do something like this
MyWave[]=Max(0, MyWave[p])
or this
MyWave[]=(MyWave[p]<0 ? 0 : MyWave[p])
or this
MyWave[]=Limit(MyWave[p], 0, inf)
