Help with graph titles and how to write a procedure to rename multiple titles at once
hedgesbk
Display Temp vs Time(secs)
TextBox/C/N=text0/A=MC "File_Name1"
Display Pressure vs Time(secs)
Display Altitude vs Time(secs)
When I load in a different file I want to change the titles from File_Name1 to File_Name2. Is there any way to write something into my procedure so that when I change the title of one, all the other ones will change to match? I am using this procedure to make around 20 graphs, and don’t want to have to change each title by hand every time I use a new file. Thanks,
BH
For most purposes, it is simpler and cleaner to just write a procedure that updates the textboxes using the same command you used to create the textboxes but with a different file name.
To target the TextBox command to a particular graph so that it works regardless of which window is active you need to use the /W flag, like this:
July 7, 2010 at 05:35 pm - Permalink
July 8, 2010 at 12:41 pm - Permalink
