R squared for quadratic fitting
thuzhengc12
I noticed that R squared seems to be only available for linear fitting, does anyone know how to get R squared for a quadratic fitting? Thank you very much!
Best,
Chu
Hi Chu,
R squared is not valid for nonlinear fitting models. Its not that long ago that I also briefly dealt with this question and I found a few references that might help:
Greetings,
Klaus
April 13, 2021 at 12:37 am - Permalink
I have previously investigated this topic and one aspect to appreciate is that in a polynomial model from a statistical perspective is not non-linear. The argument being is that what is being fitted is the coefficients and if they do not combine in a term then the equation is linear. The key insight is to focus on the coefficients not the independent parameters.
Y = K0 + K1X + K2X2 is linear in the K terms though non-linear in X which is what the scientist is focused on.
Y= K0 + K1X + K0K1X2 would be considered non-linear from statistical perspective fitting the K terms.
That said there are still concerns with R metric but it could be available. As a side note: JMP statistical package from SAS does return an R statistic from a polynomial fit.
April 13, 2021 at 06:03 am - Permalink
My take also is that R^2 is also a metric to compare the confidence we can have that data follows one linear model versus the data following a different linear model. The worst abuse that I see most frequently is not when folks use R^2 as a metric fitting non-linear models to data. Rather, the worst abuse is when folks claim that a high value of R^2 in a straight line fit to a set of measured data validates their linear model as the right fit to the data. I shudder every time I see this approach.
April 13, 2021 at 06:20 am - Permalink
In reply to Hi Chu, R squared is not… by Klaus
Thanks all!
April 27, 2021 at 08:39 pm - Permalink
While a quadratic is "linear in the coefficients", which makes the fitting process linear, the function itself is nonlinear, and that's what's important to r^2.
Even fitting a line with the constraint that it pass through zero causes problems with r^2.
April 28, 2021 at 12:07 pm - Permalink
