Better way to handle temporary data and panels
Quite often I have the need to cleanup various waves on experiment close or stop hardware as users are quitting igor with hardware running.
The waves I want to remove will be outdated when the experiment is opened again. Either because they hold some hardware state or because they are only there for caching things and I want to save disk space (we are talking about ~10-100MB per experiment).
Now from my limited understanding of the igor hooks I've come up with something like the following
/// Called before a new experiment is opened, in response to the New Experiment, /// Revert Experiment, or Open Experiment menu items in the File menu. static Function IgorBeforeNewHook(igorApplicationNameStr) string igorApplicationNameStr variable modifiedBefore, modifiedAfter ExperimentModified modifiedBefore = V_flag DoCleanup() ExperimentModified modifiedAfter = V_flag if(!modifiedBefore && modifiedAfter && cmpstr("Untitled", IgorInfo(1))) SaveExperiment endif return 0 End static Function IgorQuitHook(igorApplicationNameStr) string igorApplicationNameStr DoCleanup() End
Which does the cleanup and resaves the experiment again if required in IgorBeforeNewHook but only removes and stops stuff in IgorQuitHook. I'm skipping over BeforeExperimentSaveHook and IgorStartOrNewHook/etc. to not make it even more difficult to understand.
Now that experiment resaving takes a lot of time and is potentially dangerous as I'm doing it without the users informed consent.
How do you guys solve that problem?
I'm no expert on Hook Functions, but couldn't you simply run your cleanup function every time before an experiment is saved using BeforeExperimentSaveHook?
March 12, 2021 at 03:03 am - Permalink
I assume the DoCleanup() is the function to dump the trash in a manner of speaking. Have you considered the benefits to have the cache files stored outside of the experiment? The intent is to avoid any need to have to clean up the experiment (e.g. if it crashes). The one added benefit is that you can store a default cache file that can always be restored regardless of how the experiment "went down" (again in a manner of speaking). With some clever programming, you could even sense whether the user had stored a favorite template set that should be restored in place of the default. The downsides are that you move the overhead (time) now taken by the DoCleanup() function to a set of functions akin to WriteToCache() and ReadFromCache() and that you have to decide where the cache file is going to be stored for your package.
As for saving the experiment without the informed consent of the user ... Does the if(!modifiedBefore ...) segment support a DoPrompt call with the Yes/No request? In other words
if (...)
DoPrompt ... "Do you want to save this cleaned-up experiment?"
Alternatively, I might think that you could check whether cleanup is needed (e.g. have a CleanUpNeeded() function that returns 0 or 1) and then ask the user for permission. Finally, you could invert the the cmpstr(...) portion of your test and only do the unbidden save if a user had already saved the experiment with a real name. In this case, return 0 from the hook functions and, if I am not mistaken, Igor will also prompt the user whether to save an "Untitled" experiment or not. Otherwise, return 1 to indicate that your function is taking over what Igor normally does.
March 12, 2021 at 05:43 am - Permalink
Thanks both for your replies.
@olelytken
If I do that I would make it hard to continue measuring after saving, currently you can also save during data acquisition and this works.
@jjweimer
> External cache
If I make the cache external of the current experiment, I need a way to access that and would end up with waves from that cache inside the experiment which I would then need to delete again.
The cache has to be very fast so making it a bit slower to solve the issue here would not really be an option.
I would also like to avoid asking the user. Most users are not very firm with Igor Pro and I like to avoid any possible friction.
March 16, 2021 at 06:59 am - Permalink
Yes. Certainly. I was for some reason under the mistaken belief that one could use an external cache as a disposable storage in its own right.
My thought is equivalent to being able to use an #include pragma but for data ... #withdatafile "MyDataFile.dat".
March 16, 2021 at 07:51 am - Permalink
Would it possible to do some sort of weird gymnastics where your procedure converts your acquisition datafolder to a /free datafolder, saves the experiment, and then converts the datafolder back to a normal datafolder? Would a free datafolder be saved?
March 18, 2021 at 02:40 am - Permalink
I always have to think carefully about free anything...
In order to avoid having the free data folder be destroyed, you have to keep a reference to it. Since the reference has to exist outside of a running function (unless I'm not quite getting your solution) then it would have to be held in a DFREF wave. A non-free DFREF wave. That wave would be saved...
Igor, in fact, goes to great lengths to save and restore the free contents of DFREF and WAVE waves.
March 18, 2021 at 10:37 am - Permalink
I guess a robust solution would be a new specialized 'cache' or 'temporary' folder and panel type, which reside in memory when Igor is running but are never ever saved to disc. If the program is closed, they are gone. I would probably make use of this in my projects. No more worrying about users haphazardly leaving old (=version) and stale panels open when saving experiments would be great!
March 18, 2021 at 06:29 pm - Permalink
This seems to work for me. Test1() creates a big wave and saves the experiment with the big wave in it. Test2() saves the experiment without the big wave, but also without deleting the big wave from the active experiment. The big wave is still there after the function call.
March 19, 2021 at 01:59 am - Permalink
I think this will not work if BigWave is displayed in a graph or otherwise used (KillWaves will fail).
March 19, 2021 at 02:23 am - Permalink
True, you will have to kill the graph before saving the experiment, and then recreate it after, but it can be done with a little work
March 19, 2021 at 02:53 am - Permalink
Yes, if you keep track of everything you do not want to have saved and hide it from the user (so they cannot mess with the data) then you could pull it off by silently shifting all data into free waves and close/rebuild all graphs or panels which should not be saved. This would need to be done in BeforeExperimentSaveHook(). I wonder how difficult it would be to save a recreation macro of a panel / graph in a free text wave and then have it closed / reopened. I guess this would at least lead to a flicker or bring the panel to the front. Might be OK, though.
EDIT: Thinking a bit longer about it, I wouldn't even know how to pull this off using BeforeExperimentSaveHook(), since I guess the function terminates before the experiment is saved.
March 19, 2021 at 03:10 am - Permalink
Maybe johnweeks' suggestion of a normal DREF wave holding a reference to a free wave would keep the free wave alive...
March 19, 2021 at 03:58 am - Permalink
On second thought. I would end BeforeExperimentSaveHook() with a SaveExperiment command and then cancel the whole ExperimentSaveHook chain. That should be possible, or?
March 19, 2021 at 04:05 am - Permalink
Yes, but I have no idea how to cancel the save process from within BeforeExperimentSaveHook(). The help does not say anything in this regard. I haven't tested anything in this regard, though.
March 19, 2021 at 04:10 am - Permalink
I believe that olelytken's approach would work to save the experiment without also saving the free wave, but I think it is playing with fire (though very clever).
In IP9, you would probably be better off using MoveWave instead of Duplicate + KillWaves so that the wave doesn't actually need to be copied. I'm not sure if MoveWave can do this in IP8---based on the documentation I don't think it can.
Anyone using this technique must keep in mind the fact that if there is an error that stops function execution, or if the user stops execution (either by aborting or perhaps in the debugger), the BigFreeWave reference count will drop to 0 and it will automatically be killed. So make sure that whatever is in BigFreeWave is completely expendable. It sounds like in Thomas's case it is.
Igor does have an internal concept called a homeless wave that is essentially what Thomas is requesting. This is a wave (it can even be displayed in a graph) that is not connected to the global hierarchy in any way and which is therefore not saved with the experiment. I believe that contour plots use homeless waves, and they are also used in the Data Browser in some situations. There is currently no way for user code to create or otherwise interact with homeless waves. The fact that they can be displayed in graphs makes them dangerous because if the wave is killed without the graph being killed first, Igor will crash. So exposing homeless waves to user code is something we would be very hesitant to do. But we would be interested to hear how users might use such a feature if it existed.
March 19, 2021 at 05:37 am - Permalink
but fire is so irresistible :)
I tried a version with a wave reference wave pointing to a free wave, see the example below, but if I save this experiment the free wave is saved with the experiment.
March 19, 2021 at 05:59 am - Permalink
In reply to but fire is so irresistible … by olelytken
Right, that's the expected behavior. The global root:BigDataReference wave holds a reference to the free BigData wave, so it's saved in the experiment. In your earlier example the wave reference to the free wave existed only within the Igor function itself, but there was no reference to that free wave from anything in the global space, so it's not saved with the experiment.
Another potential problem with relying on this behavior is that it may not actually be intentional on our part, so it's possible this could change in the future.
March 19, 2021 at 06:04 am - Permalink
I rather would be happy about a method to keep panels from being saved, preferably without killing them during the save operation. Would it be possible to introduce a flag to mark graphs, panels (and waves) as locked / transient for the saving process?
March 19, 2021 at 06:09 am - Permalink
I just reread the documentation for "BeforeExperimentSaveHook" and played around with it some more. And I think I misunderstood how it works. You don't need to call SaveExperiment in it, as you are called *before* the experiment is saved. And the user already choose to save as well.
Being able to mark things as transient sounds like a good idea. This would probably need to be inheritable, meaning a graph displaying a transient wave would also be transient. And transient datafolder would be a bon as well.
Or maybe we need another set of hooks which allow to mark something as transient just before saving?
Something like
but that would need to be called for every object in IP. And would probably be dead slow.
March 19, 2021 at 07:54 am - Permalink
I want to draw renewed attention to my posting a ways back:
Yes, saving free waves is deliberate. It is driven by the fact that a non-free DFREF or WAVE wave will keep free waves alive. If we didn't do this, we would have to go to some great lengths to avoid crashing on loading a wave full of pointers to nonexistent waves.
Adam can look at the convoluted code in Igor that saves DFREF and WAVE waves!
March 19, 2021 at 10:11 am - Permalink
Homeless sounds a bit forlorn. How about expendable or trashable or purgeable.
make/N=.../EXPEND
make/N=.../TRASH
make/N=.../PURGE
Such operations would create (globally accessible) waves that would reside in their own "sandbox", perhaps even in their own data folder directory spaces. These waves would disappear when the experiment is closed or quit (i.e. be purged). The programmer would be responsible to check for their existence or to transfer their contents to permanent storage when needed.
They could be the meta-goal of all free waves ... be resident not just for the life of a function but for the life of the open experiment.
I could live with any requirements that might be needed to make clean-up easier. For example, I would have no problems when such waves could not be graphed or used in dependencies.
How would I use them? Depending on the performance improvements or the ease in administrative oversight, I might have one master Init function that would create these waves rather than creating the same kinds of /FREE waves in a host of comparable function calls. It is the equivalent of knowing that you have a second desktop where you can scribble around and when you come back the next morning to start again, you have a fresh desktop.
March 19, 2021 at 11:01 am - Permalink
A big part of the reluctance we might have for "trashable" waves is the need to restrict their use. Since free waves were introduced, we have been closing the loopholes in how they can be used. When they were new, we had crashes reported from making graph traces with free waves. Just recently we closed a loophole in which a free data folder was made the current data folder (perfectly OK), but then a new folder was made inside it and made to be the current data folder. That released the only DFREF and the folder died. Igor crashed trying to restore the current data folder.
Think of the many ways a wave can be used that require persistence. Like graphs, dependencies, use as a value for a control, many other uses. All of which need to be checked.
@jweimer We use an int32 for operation flags, so they have to be four characters or less.
Make/N=.../XPND
Make/N=.../TRSH
Make/N=.../PURG
We try to avoid actual four-letter words! :)
March 19, 2021 at 02:07 pm - Permalink
I appreciate the effort.
> We use an int32 for operation flags, so they have to be four characters or less. ... We try to avoid actual four-letter words! :)
Oh, I see a Jeopardy box here. ... A four letter phrase that is never a four letter word. What is a flag in Igor Pro?
(This in itself gives thoughts to a rather interesting adventure ... Let's create Igor Pro Jeopardy game).
I like XPND as eXPeNDable.
March 19, 2021 at 07:33 pm - Permalink
In reply to > Since free waves were… by jjweimer
Well, to me that looks like eXPaND. On the other hand, I can't find 'XPND' in our source code, so at least it wouldn't be an inconsistent use. You must have noted that Igor is a model of consistency (sarcasm over with) :)
But this is all theoretical unless we actually implement something like this!
March 22, 2021 at 03:27 pm - Permalink
