Loading files
Code builds a path to a specific file based on year and month and data station. It works fine when the 7 files are present. If a file is missing it errors and asks the user if they want to help find the file. I would like to avoid the needed user input by checking to see if the file is present before the Loadwave command is executed. If it's not present then execute the Else portion of the If statement and then move on.
FUNCTION LoadAB(yr,month,days)
    Variable yr, month, days
    Variable/G Arraylength
    Arraylength = days*1440
    string monnum, filepath, filepath1, filepath2
    variable flag=8
//  filepath = "P:Metdata:"  //For use on a PC Replace the P: with the letter of the correct drive.
//This section builds the path to the file for the loadwave commamd
    filepath = "Mac Passport:Metdata:"  //For use om my MAC. Use the drive name.
        If(month < 10) //For single digit month numbers
            filepath1 =  num2str(yr)+":raw:QA:"
            filepath2 ="0"+num2str(Month) +"_CR1000_10A.txt"
        Else    //For 2 digit month numbers
            filepath2 = num2str(Month) +"_CR1000_10A.txt"
        EndIf
    filepath += filepath1; filepath += filepath2 //Builds the path for the loadwave command
    //The path to the file will look like this. The filename changes each month
        //Mac Passport:Metdata:2021:raw:QA:02_CR1000_10A.txt
    //If the file is present I want to load it and if it's not
    //print the file not found statement.
    IF(//What goes here)
        LoadWave/O/A/J/D/W/K=0/L={0,1,0,0,0}/R={English,2,2,2,2,"Year-Month-DayOfMonth",40}  filepath
        Wave Tmstamp, WS_10m, WD_10m, WD_SD_10m, WS10Gust, Temp_10m, Temp_2m, Baro_2m, RH_2m
        GetTime(Days)
        RevMissingLines10()
        Make /D/O/N=(arraylength, 9) Ten_A
        Ten_A[ ][0] = Tmstamp[p]
        Ten_A[ ][1] = WS_10m[p]
        Ten_A[ ][2] = WD_10m[p]
        Ten_A[ ][3] = WD_SD_10m[p]
        Ten_A[ ][4] = WS10Gust[p]
        Ten_A[ ][5] = Temp_10m[p]
        Ten_A[ ][6] = Temp_2m[p]
        Ten_A[ ][7] = Baro_2m[p]
        Ten_A[ ][8] = RH_2m[p]
        Else
            Print "File not Found:", filepath
    ENDIF
There are a couple of ways:
Open/R/Z=1 then check V_flag. It will be zero if the file was opened. Then call Close before calling LoadWave.
GetFileFolderInfo
I don't know which is faster, probably the GetFileFolderInfo operation; it is newer than Open by a number of years!
