Constraints in TextWaves for ThreadSafe FuncFit
ggermer
Currently you have to create a matrix and a 1D wave containing the information of the constraints text wave. Please add the possibility to use constraint text waves for ThreadSafe FuncFits. The current solution is impractical, especially if you want to change the parameters or understand them directly from the source code.
Unfortunately, the code that parses those text waves uses Igor's interpreter, which is not thread safe. That was my solution to recognizing the various symbols that you can use there. The interpreter is ancient code rife with globals, and is unlikely ever to be threadsafe.
My only offering is that you can call CurveFit to generate the required waves using the /C flag. Note that this is a "flag" which means one of the flags right after CurveFit or FuncFit. There is also the /C "parameter" down at the end of the command that specifies the constraint specification.
November 23, 2020 at 05:10 pm - Permalink
The format of the waves required is described in DisplayHelpTopic "Constraint Matrix and Vector". It is not entirely opaque, just mostly :)
November 23, 2020 at 05:11 pm - Permalink
I have tried it this way and it works well, but it is just complicated. This was the reason of my wish.
Alternatively, would it not be possible to implement the "/C" as a separate function that converts a text wave into the two needed waves (without performing a fit)?
Quick and dirty version:
string importstring=""
variable v_num_rows=Dimsize(w_T_Constraints,0)
variable index
for (index=0;index<v_num_rows;index+=1)
importstring+=w_T_Constraints[index]
importstring+=";"
importstring=replacestring("K",importstring,"")
variable v_items=itemsinList(importstring)
make/O/N=(v_items) temporary_wave
for (index=0;index<v_items;index+=1)
temporary_wave[index]=str2num(StringFromList(index,importstring))
make/O/N=(v_items,number_of_Ks) M_FitConstraint=0
make/O/N=(v_items) W_FitConstraint
string tempstring
string s_replace
variable v_row=0
variable v_read
tempstring=StringFromList(index,importstring)
if (StringMatch(tempstring,"*>*")==1)
s_replace=num2str(temporary_wave[index])+" >"
tempstring=replacestring(s_replace,tempstring,"")
v_read=str2num(tempstring)
M_FitConstraint[v_row][temporary_wave[index]]=-1
if (v_read==0)
W_FitConstraint[v_row]=v_read
W_FitConstraint[v_row]=(-1)*v_read
s_replace=num2str(temporary_wave[index])+" <"
M_FitConstraint[v_row][temporary_wave[index]]=1
v_row+=1
killwaves temporary_wave
November 24, 2020 at 05:07 am - Permalink
I have entered your idea in the wish list. Unlikely to make it into Igor 9.
November 25, 2020 at 09:12 am - Permalink
Ok, thank you.
November 27, 2020 at 07:10 am - Permalink
