Scatter dot plot in Igor
simpi
I recently moved from Igor 6 to Igor 8.
I cannot just to figure out how to do a scatter dot plot.
Igor 8 is not doing it ???
It should be the same. Create New Graph, select x and y. Once generated double click on trace to open trace modify and set modes to dots.
Also you can right click on trace and set mode to dots from contextual menu.
October 28, 2020 at 08:57 am - Permalink
This is the graph I am speaking about
October 28, 2020 at 09:30 am - Permalink
That is a category plot and it should also be done the same way. Can you share a bit of data in an experiment file?
October 28, 2020 at 09:44 am - Permalink
The Scatter Dot Plot package still ships with Igor 8, and it should still work just like it did in Igor 6. What do you see in the menu
Windows->New->Packages? Scatter Dot Plot should be there.
In Igor 8 you can also use a box plot and simply set the box and whisker lines to zero thickness. You can also use a violin plot the same way.
October 28, 2020 at 10:35 am - Permalink
There is not option Packages in Windows->New
Maybe I have to "activate" ?
October 28, 2020 at 12:00 pm - Permalink
Yes, but it is more complicated if I have to modify the graph....
October 28, 2020 at 12:06 pm - Permalink
Sounds like you have a broken Igor installation. Are you using a Macintosh by any chance?
October 28, 2020 at 03:06 pm - Permalink
yes and no, it is on windows but on mac laptop
October 28, 2020 at 09:54 pm - Permalink
Choose Misc->Path Status and click home. The path should be something like "C:\Program Files\WaveMetrics\Igor Pro 8 Folder". If not, there is something wrong with your installation. It may be that you dragged the Igor64.exe icon out of the "Igor Pro 8 Folder".
October 29, 2020 at 03:40 am - Permalink
