Controlling a USB camera in Igor Pro 8
Dear all,
I have recently upgraded my Igor Pro software from the version 6 to 8.
BTW, great improvements! Bravo!
In Igor Pro 6, I used to control a USB 8-bit CCD camera using the DSXOP (DirectShow).
It worked well, as I had access to the camera settings (via a settings panel) such as the gain, the exposure time, etc.
Now I have switched to Igor Pro 8, I do no longer have access to the DSXOP.
I played a bit with the new commands "NewCamera", "GetCamera" and "ModifyCamera", but I cannot find a way to get access again to the camera settings panel.
The type of the camera does not matter, as I have the same issue with a regular USB webcam.
Can someone help me on this subject?
If it is not possible to have access to the camera settings panel in Igor Pro 8, is it possible to use the old DSXOP in Igor Pro 8?
If yes, how?
Thanks for your help.
First what operating system are you on?
Make sure camera is plugged in before launching IP8.
When you run:
GETCAMERA availableCameras
what does IP8 return as a string? For example on my Mac laptop I get " FaceTime HD Camera".
September 29, 2020 at 06:05 am - Permalink
Hi Andy,
I am on Windows 7 64 bits.
I made sure the camera is plugged in before launching IP8. I can actually open a video window of the camera in IP8.
The issue is that I cannot change the settings of the camera, such as the gain, the exposure time, etc., like I could do with DSXOP.
When I run "GetCamera availablecameras", I get "StUSBCam".
Hope it helps...
September 29, 2020 at 07:33 am - Permalink
Ok IP8 sees that a camera is available and there is only one.
When you issue the command
NewCamera
The expected behavior should be in a few seconds a new window will open with the name camera0.
What happens? If no window pops up is there an error message?
September 29, 2020 at 07:46 am - Permalink
When I issue the command "NewCamera", a new window does open with the name camera0.
This is not the issue.
My problem deals with the adjustment of the settings of the camera (gain, exposure time, etc.), which I do not have access to, unlike I did with the DSXOP in IP6.
September 29, 2020 at 08:19 am - Permalink
I believe that ModifyCamera is the only way to change these settings.
September 29, 2020 at 02:34 pm - Permalink
Some cameras do not have access to the settings via USB. I had to have custom driver written for a project of mine to control a Baesler camera even though it showed up via the USB driver. I just did have access to the settings.
September 29, 2020 at 02:53 pm - Permalink
Both of the posts above are correct. The only way to control the settings of the camera is via ModifyCamera. You are out of luck if it turns out that your camera driver does not support the particular protocol that Qt uses.
Since you are working on Windows and you have access to IP6 you may want to keep the old Direct Show XOP around just for image acquisition. It is simpler than having an XOP written and if you care careful, you should be able to move experiments between the two versions of Igor.
September 29, 2020 at 04:29 pm - Permalink
