Drag Wave from Browser into SetVariable
njprotic
I have a panel with a SetVariable widget which assigns a wave name/path to a string variable, e.g. "root:someFolder:waveName". I would like to write some kind of hook function such that I can just drag the wave from the data browser into the SetVariable widget to set the string variable, similarly to how one can drag a wave from the data browser to the command line. Is something like this possible?
No, nothing has changed in the last day with regards to this: https://www.wavemetrics.com/forum/general/drag-and-drop-setvariable
Igor 9, soon in beta, will support user-defined contextual menus in the data browser's object list, so that feature might be of some use to you in this situation.
September 2, 2020 at 12:13 pm - Permalink
